04 GT 6 quarts of oil and dipstick reads below minimum
Like the title says, i got my oil changed with a new filter and saw the mechanic put 6 quarts of the oil i bought in my car, i checked the dipstick and it was just a tad below minimum. he explained that i might just have to drive around, and since..my oil level is still a tad below minimum. 3 months ago the same amount of oil brought it just a tad over max.
What has happened to my engine? |
2003 ford mustang gt
13.9 stock
u got to wait a few for all the oil to get back to the oil pan, plus not all oil will return back some stays in the head to keep it lubed up for wen u start it. now do u see black smoke coming out of ur tail pipe or oil on the floor?
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
1999 Mustang GT;1991 lx
Blue smoke, you're burning it
then obviously look for leaks. They make a dye you can put in the oil and use a black light to see leaks. |
#4 | |
As others have said the manner in which, and timing of when, you check the oil level can greatly impact the dipstick readings--with the most important piece being that the engine needs to sit for a bit to make sure the oil has drained back to the sump, and that you consistently check the level under the same conditions. Here's is a Ford TSB regarding oil levels that explains how to properly check and interpret the level.
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
1998 Mustang GT
1:34.43@13.86
dude that thing holds like 5.2 or something, if you over fill it thats bad. and yeah you have to let the oil cycle down to the pan, its thick as fuck too when its cold.
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
#6 | |
Ford responded to this by changing the recommended fill and the dipsticks--that's all; check out the owners manuals here and you will see the altered spec.
#7 | |
12.73@111.36
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
Threads Similar to: 04 GT 6 quarts of oil and dipstick reads below minimum
| How many quarts? | mystang0673 | 99-04 | 18 | April 17th, 2011 11:58 PM |
| What's the bare minimum wiring needed? | OKC5.0 | 5.0 Mustangs | 0 | October 1st, 2009 04:11 PM |
| minimum offset for GT | Alexander III | 2005 - 2010 | 7 | December 26th, 2007 11:14 AM |
| Where to get a speedo reads at least 160? | Alexander III | 2005 - 2010 | 15 | December 24th, 2007 01:32 PM |
