Hey Casper......... got a trans question for ya. - Page 3
Old March 13th, 2011, 11:28 PM   #41
Mustang46's Avatar
11.85 @ 125
Mustang46 has a spectacular aura aboutMustang46 has a spectacular aura about
Originally Posted by 86er View Post
shouldnt have to change any wires. You unplug the 5spd harness, plug in the auto harness, run it down the trans to the connectors and and o2's and thats it. Its all ford does between the two different cars.
Did you change the pcm to an auto pcm?
yeah I swapped everything myself out of the car. I installed my 5-speed in the guys car and I took his auto. We swapped everything.
Old March 14th, 2011, 01:18 AM   #42
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
The harness and everything should plug right in. You shouldn't have to mess with changing any wires. I just did the swap about 6 months ago.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old March 14th, 2011, 01:23 AM   #43
Mustang46's Avatar
11.85 @ 125
did you have to fix any fuses or anything special?
Old March 14th, 2011, 01:43 AM   #44
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
There is a small jumper wire that need to be put in place of the clutch pedal position switch, but I'm sure you swapped that over cause you would have had to remove it from the auto car to put the 5-speed in. There is nothing weird about the swap. It is very straight forward. I am willing to bet money that your problem has to do with your shift solenoids not being bolted down.
Old March 17th, 2011, 09:38 PM   #45
Mustang46's Avatar
11.85 @ 125
well i just bolted everything down and got everything back together. Started it up, let it idle for about 5 min, and then drove it down the street. Still NOT shifting.....eeeeerrrrrrhhhhh...... Tomorrow is another day and I have checked all the connectors exept for the connector behind the engine. I couldn't just quickly get my hand back there to check but tomorrow I will check it. Its 9:30 here on the east coast so I am calling it for the night. If you all have any other suggestions please share.
Old March 17th, 2011, 09:43 PM   #46
Mustang46's Avatar
11.85 @ 125
****EDIT**** Looking at the picture, its circled. Its held in by a c clip. Careful, its in there with a lot of pressure. You need to push up on it before you remove the c clip. I just put an 1/2 wrench extension on a jack, jack the jack up until the extension is pushing the unit off the c clip. Then slowly let the jack down.
Luckily the spring is like 20 bucks if its bad. Then just reverse the above to install it and thats it. Really simpler than it sounds.
Let me look for a diagram
I checked the sping when I had the spring out and I was actually able to push it up by hand. I took out the spring and it looked fine. Is it supposed to hard to get out. Remember the car has sat a while.
Old March 17th, 2011, 10:26 PM   #47
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
It depends on how many and what springs were in there. A lot of guys only run one spring in the 1-2 accumulator. In that case, there won't be any tension on it and will be very easy to get in and out. Even with the two stock springs in there, it should come off fairly easily. I just did mine by hand yesterday.
Old March 17th, 2011, 11:18 PM   #48
Mustang46's Avatar
11.85 @ 125
There was just 1 spring. well I am definately missing something. I am going to test the electric to the solenoids tomorrow also. Just realized that the O/D button is not working. I checked the fuse and it is hooked up and working. I don't know what else it could be other than the trans not getting juice down there.
Old March 20th, 2011, 06:32 PM   #49
Mustang46's Avatar
11.85 @ 125
OK......... NOW I'M SCREAMING!!!!!!!!!!!!!! IT SHIFTS!!!!!!!!
I had a hunch on the tune that I put on the car to make it run and WALLAH!!!!!! The stupid piece of junk started shifting. Talk about making a person kick and scream! I thought I was going nutz.
Here is the low-down of the series of events that has lead to my insanity
I installed the automatic trans and all but I knew that the tune that was on the car wasn't going to work so before I did the swap I had returned the 5-speed computer back to the stock tune so I could reprogram the auto computer. Well I then took the the programmer to my tuner to have him transfer the engine parameters to the automatic computer in order for the car to run and drive because with the stock tune the car would not run. Well after all the runaround and trying to figure the stupid thing out I finally put on the old set of Mass-Air/injectors and returned the car to the stock tune. Well, well, well, what do you know......it shifted. So now I have to putt it down to my tuner and probably have to run over his toes!
Thanks guys for all your help! I repped all of you for great advise and patience.
Thanks Again!
Old March 20th, 2011, 06:36 PM   #50
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
glad to hear it all worked out for you, now make your reservations for NMRA columbus so I can see the car go down the track.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old March 20th, 2011, 06:39 PM   #51
Mustang46's Avatar
11.85 @ 125
I was thinking about doing something here soon. I still have to get my heads, intake and fuel system. Looks like my heads are going to take the longest. And then have it retuned. Maybe then I will make some real power.
Old March 20th, 2011, 06:42 PM   #52
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
columbus isn't untill labor day weekend, you've got time.
2012 300a GT auto
Old March 20th, 2011, 06:53 PM   #53
86er's Avatar
glad to hear you figured it out, nothing feels like a great accomplishment than figuring a problem out
Just a truck
Old March 20th, 2011, 11:03 PM   #54
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
Gla to hear the car is up and shifting finally! Can't wait to hear how the swap does for your track times.
Old March 20th, 2011, 11:05 PM   #55
Mustang46's Avatar
11.85 @ 125
yeah but now it's throwing codes. I'm getting a Transmission Range Sensor codes. P0708 and P01702
Old March 27th, 2011, 07:09 PM   #56
Mustang46's Avatar
11.85 @ 125
OK guys.......................... EVERYTHING IS FIXED!!!!!!!!!!!!
The Transmission Range Sensor AKA "Safety Neutral Switch" was bad.
Now the only thing I need is an O/D switch. Mine is broken. but it's all working correctly now.
Thanks everyone for the help!
Threads Similar to: Hey Casper......... got a trans question for ya.
85 trans question mutlyi4 5.0 Mustangs 6 November 12th, 2010 03:25 PM
trans is down, casper where you at bro?? o2gtstang 99-04 20 June 3rd, 2009 01:28 AM
Trans question. VOLIPINO Modular Mustangs 3 April 18th, 2008 08:43 AM
Trans question. VOLIPINO 5.0 Mustangs 12 April 17th, 2008 09:55 AM
Trans question. VOLIPINO Modular Mustangs 0 April 16th, 2008 07:59 AM
