Nitrous Timing
Old April 26th, 2007, 08:14 AM   #1
zerofx150's Avatar
2003 GT
13.6 @ 101
zerofx150 is on a distinguished road
Send a message via AIM to zerofx150 Send a message via Yahoo to zerofx150
Nitrous Timing
is anybody running the steeda timing adjuster with nitrous, to retard timeing? And is the general rule of thumb 2* per 50 shot?
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports.
Old April 26th, 2007, 10:22 AM   #2
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
I took mine off because I can adjust my timing with my tuner. I have also been told by numerous techs that the timing adjuster is kind of worthless on our engines.
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Old April 26th, 2007, 11:46 AM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
you can run 75 on stock without a problem. you can even run a 100 shot without a problem. after that then timing will be an issue. if you wanted to retard timing start at 2 degrees at 100 and 1 per every 25. i am now at 125 with stock timing without a problem but i am about to go back 2 degrees just to make sure.
Old April 26th, 2007, 09:38 PM   #4
zerofx150's Avatar
2003 GT
13.6 @ 101
so would the timing adjuster be worth the time and effort if i don't have a tuner to be safe and get the most out of the nitrous? BTW what plugs did you run and what gap?
Old April 26th, 2007, 09:40 PM   #5
Proud American
MustangMatt96GT's Avatar
Buy a tuner it will help out in the long run!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old April 26th, 2007, 10:11 PM   #6
zerofx150's Avatar
2003 GT
13.6 @ 101
yes i know that a tuner will be better in the long run, i'm asking as a temporary deal. I'm in the process of trying to sell my truck and depending on the deal i'm either gonna have an X-cal or not. jury is still out on that plan (computer issues, etc)
Threads Similar to: Nitrous Timing
Timing WombRaider 5.0 Mustangs 1 October 22nd, 2007 11:22 AM
Nitrous and what should I set my timing at Steves LX General Tech 2 September 28th, 2007 06:51 PM
Retard Timing for Nitrous marcfiebka 99-04 8 July 10th, 2007 10:30 PM
Timing Adjust For Nitrous ChrisJ General Tech 7 July 18th, 2006 09:25 PM
