4.6 blocks
Old March 17th, 2011, 06:34 PM   #1
40thmustanggt's Avatar
40thmustanggt will become famous soon enough
4.6 blocks
is there any diffrence in the 96-98 blocks vs the 99-04? how much power can the stock block hold? my car will be paid off soon and im looking to make it a track car.. i know about the non pi vs pi stuff im just wondering about the blocks..
Old March 18th, 2011, 05:02 AM   #2
99 mustang GT
ForestGRN_Ghost will become famous soon enough
Send a message via MSN to ForestGRN_Ghost
i belive they are. with the exception of cobra blocks. they are aluminum.
Old March 18th, 2011, 05:35 AM   #3
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
The stock GT rotating assembly can handle 400rwHP or so, with some headroom left--the general consensus is that the rods are the weak point.
I asked this question of a friend who has been in the tuning business for over 25 years; without hesitation he said (exact quote) "They break at 420rwHP, you can set your watch by it." If you search the forums you'l find a bunch of tales of them blowing up, in use and on dyno's, at 400 to 430rwHP.
Also consider that Ford was not comfortable building the 390fwHP (flywheel) Cobras on the GT rotating assembly, they likely had a pretty good grip on what it could handle and meet their design life criteria.
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old March 18th, 2011, 05:52 AM   #4
Kevin C's Avatar
2001 Mustang GT
34.82 @ 21
Kevin C will become famous soon enoughKevin C will become famous soon enough
Around 400 RWHP is typically the general consensus for a stock cam, unported stock head, blown 2V. On 3 Performance made 440 RWHP 496 RWTQ on an otherwise bone stock single turbo 2002 GT.
Imagine if they threw on some MMR ported Trickflows, MMR turbo cams, in the name of efficiency. Not just turning up the boost, and being able to grenade the stock internals with that sort of accuracy.
I love a good centrifugal setup, but turbos have the edge in efficiency, therefore raising that little threshhold of what a 2V can do on stock internals.
'01 GT - T56 6 Speed - Centerforce DFX - SCT LiveWire - Borla Stingers - Magnaflow Catted X - Steeda Tri Ax - Cobra Aluminum Driveshaft - 3.73s - Eibach Pro-Kit - MM Full Length Subframe Connectors - MM Caster Camber Plates
Vortech V1 sold
Old March 18th, 2011, 08:47 AM   #5
2SLO2GO's Avatar
2SLO2GO is on a distinguished road
im sittin right at 400/393 with stock cams and 10lbs. putting in stage 1 cams this weekend with a new tune directly to follow. i found a teskid shortblock for 350 bones!!!!
Old March 18th, 2011, 11:14 AM   #6
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
I'm not sure if these guys are answering what you're asking, they are all talking about the internals... As far as the blocks go, the iron blocks are strong as hell and can handle over 1000 rwhp. If you find a Teksid they are still plenty strong and can handle at least 800+ and some say up to 1000 rwhp.
Do the Right Thing, Cook. ~Zip.
Old March 18th, 2011, 09:15 PM   #7
thank you this is what i was looking for!! now if the stock block can handle up to 1000hp why do people buy the mmr 900 blocks and what not? also someone explain to me if you change a non pi motor over to pi you get a bump in compression along with alittle more power?
Old March 18th, 2011, 09:24 PM   #8
2SLO2GO's Avatar
according to the first paragraph its 1500 hp for basis design
Old March 18th, 2011, 09:27 PM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
people buy the mmr 900 motors cause they are built sb's. i ran one in my last stang. block prep is around 500, and a new block is 600. mmr also charges 300 dollars to balance and install the rotating assembly so it is cheaper in the long run to buy a assembled sb from them.
Old March 18th, 2011, 09:39 PM   #10
86er's Avatar
a teksid short block is junk, except for the block.
a teksid block will handle what ever you throw at it, no if's and or buts about it.
Just a truck
Old March 18th, 2011, 09:46 PM   #11
2SLO2GO's Avatar
so 350 bucks worth it???? i think yes ha ha ha ha!
Old March 18th, 2011, 09:58 PM   #12
so im looking to start building the mustang will be paid off in a few more months.. whats my best bet? mmr block or stock block? id like to do H/C/I with alittle juice.. i really want to do all the work myself but ive never tore down a motor or rebuild one. i am good at taking things apart and putting them back together though.. should i attempt this or pay to have it done?
Old March 18th, 2011, 10:01 PM   #13
stal94gt's Avatar
2003 mustang v6 ;)
slow
mmr blocks are stock blocks. what makes them handle more is the manly pistons, manly rods, and kellog cranks they put in them. for h/c/i you could use your stock bottom end, but if your wanting to make some big power on spray for forced induction i would upgrade to a built shortblock and if you dont have a lot of wrench time i would buy a built long block and just drop it in and go.
Old March 18th, 2011, 10:39 PM   #14
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
+1, 800hp limit is just a joke. if you search i am sure you can find 2000hp teksids
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old March 18th, 2011, 10:42 PM   #15
2SLO2GO's Avatar
there are a few ive seen in tn!
Old March 18th, 2011, 11:19 PM   #16
I'm going On A Manhunt!
kyle2002stang!'s Avatar
2002 true blue GT
speed of time @ 88mph
kyle2002stang! is a jewel in the roughkyle2002stang! is a jewel in the roughkyle2002stang! is a jewel in the roughkyle2002stang! is a jewel in the rough
the teksid is by far the strongest 4.6 block ford produced from the factory. i wouldnt be surprised to see them holdin up to 1500hp. they came in the 96-98 cobras and the 93-98 lincoln mark8's. the major weak spot in the 99-04 GT's is the stock internals that can only handle 400rwhp, not the block.
mac lt's, mac O/R H pipe, spintech super prostreets, JLT RAI, 14"antenna, mach 1 chin spoiler, two 12" kickers.
Old March 18th, 2011, 11:26 PM   #17
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
WhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really nice
Send a message via AIM to WhiteVenom
google:
Windsor block
Teskid block
Romeo block
^ Compare and contrast and pick whats best for you
/thread.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old March 18th, 2011, 11:27 PM   #18
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
Ive been told my dcook this is no longer true as i thought it was.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old March 18th, 2011, 11:28 PM   #19
2002 true blue GT
you sure? everything ive read says the teksid is strongest
Old March 18th, 2011, 11:31 PM   #20
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
I was sure it was the strongest but i was told by an army of people that it is not. Mostly because aluminum contracts and expands depending on the weather. A video of a 2000 hp teskid block car was posted though...
Windsor is the strongest i guess. It doesnt matter they will all hold over 800rwhp without a problem.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Threads Similar to: 4.6 blocks
5.0 blocks blueovalbleeder 94-95 23 June 17th, 2009 06:07 AM
dss blocks chaosstangman 5.0 Mustangs 2 August 28th, 2008 05:17 PM
302/351 blocks sleepinggt 5.0 Mustangs 4 September 16th, 2007 11:48 PM
Engine Swap: Small Blocks or Big Blocks Speedstang302 5.0 Mustangs 32 April 15th, 2007 10:34 AM
4.6 blocks beheivjer 96-98 1 January 19th, 2007 11:36 AM
