tire pressure question
Old March 18th, 2011, 07:46 PM   #1
04gtvert's Avatar
04gtvert is on a distinguished road
Finally made the switch to deep dish 10.5s with 315 Nitto 555s from American Muscle. It says on the packaging they were filled to 44 psi for shipping. What psi should I be running in these tires for daily driving? Also, anyone else have problems with one wheel/tire sticking out further than the other one?
Old March 18th, 2011, 07:51 PM   #2
2SLO2GO's Avatar
2SLO2GO is on a distinguished road
i cant answer the sticking out problem. But i can help help with the psi. I run the reccomended pressure during regular driving. usually lower it to about half that if i want a bigger contact patch
Old March 18th, 2011, 07:52 PM   #3
2003 Mustang GT
mutag03 is on a distinguished road
30-35 PSI for street driving
Drop to about 20 PSI if on the 1/4
Old March 18th, 2011, 08:08 PM   #4
brody904's Avatar
12.9@113
brody904 has a spectacular aura aboutbrody904 has a spectacular aura about
I have a similar setup and run 30 in the rear and 32 in the front... Drop it to about 20 at the track.
If it is sticking out further on one side than the other and both wheel offsets are the same, then it could have to do with your rear axel. (assuming you are refferring to the rear)
I'd have that looked at...
Blown
390rwhp, 389ft-lbs at 11.9psi (See garage)
Old March 18th, 2011, 08:38 PM   #5
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
most mustangs have a wheel that sticks out farther than the other. its just the inconsistant build from the factory
Old March 18th, 2011, 08:40 PM   #6
brody904's Avatar
12.9@113
I've never noticed or heard that before...
Blown
Old March 18th, 2011, 08:47 PM   #7
2SLO2GO's Avatar
i also agree that mine are centerd as well. ya got stock upper and lower controls arms?
Old March 26th, 2011, 09:52 PM   #8
04gtvert's Avatar
Thanks I set them at 32. Yes I'm talking about the rears and yes my suspension is stock other than lowering springs. I've found online that this is a fairly common problem.
Old March 26th, 2011, 09:53 PM   #9
04gtvert's Avatar
I'll try to get some pics up tomorrow.
Old March 26th, 2011, 10:10 PM   #10
ytngt has a spectacular aura aboutytngt has a spectacular aura about
I had the same setup and used 25-30 psi for street lower for strip higher for autoX.
Old March 26th, 2011, 11:52 PM   #11
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
if your axle isn't centered properly, you could have tweaked upper control arms, bad bushings or where they bolt to the chassis could be bent. Adjustable upper control arms can help you center your axle.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Threads Similar to: tire pressure question
Tire pressure for 555r on street? (Tire life) 23psi max? 01MGGT 99-04 13 December 1st, 2010 01:54 AM
What tire pressure to run. 06GreenMachine 2005 - 2010 1 June 13th, 2010 03:19 AM
NEED HELP!!! Tire Tire Pressure Sensor Fault!! On Mr.Stang08 2005 - 2010 7 March 7th, 2009 12:14 PM
Tire Pressure usafimj 2005 - 2010 30 October 11th, 2008 12:36 AM
Tire pressure Blackblurr_00GT Modular Mustangs 3 April 16th, 2007 08:17 PM
