Hood Insulation
Old April 26th, 2007, 11:25 PM   #1
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
Hood Insulation
I was thinking about removing my hood insulation cause it rides on my supercharger and makes it look like crap. Are there any consequences to this solution? I also heard it makes the engine bay run cooler? Is that true?
2004 GT Boosted by Vortech
Old April 26th, 2007, 11:26 PM   #2
Proud American
MustangMatt96GT's Avatar
I does nothing if you remove it! personally I like mine! But then again my running pony is painted white!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old April 27th, 2007, 12:42 AM   #3
MnrlGry01gt is on a distinguished road
I dont have one
Old April 27th, 2007, 12:48 AM   #4
Blackblurr_00GT's Avatar
Y2K GT
13.3@103
Blackblurr_00GT is on a distinguished road
dosent the hoood insulation keep the fiber glass hood from warping or getting heat damage you like if the sun was shining on from both sides
Old April 27th, 2007, 12:49 AM   #5
Garhfer's Avatar
How does the sun shine from both sides of the hood?
Old April 27th, 2007, 12:50 AM   #6
Y2K GT
13.3@103
i was just trying to get at like the heat from the sun not the atcull light
Old April 27th, 2007, 12:52 AM   #7
Garhfer's Avatar
Heh, I've heard that it could ruin the paint on the hood from the heat of the engine... is that true?
Old April 27th, 2007, 12:56 AM   #8
Y2K GT
13.3@103
i dont know but i would think thats one reson for having the insulation i mean i heard on carbonfiber hoods after so in the sun they well start to get weak and you should paint them but heck what do i know
Old April 27th, 2007, 06:48 AM   #9
2001 Mustang GT
amphibrecon is on a distinguished road
Nah take it off, mine never had it and no problems. Then take your scoop off, cut a hole in the hood under where the scoop sits, smaller than the size of the scoop, then bore (drill) out all of the little circles on the grill insert then replace scoop, makes the scoop somewhat functional
YOUR DAYS OF FINGER BANGIN' OLD MARY JANE ROTTEN CROTCH THROUGH HER PRETTY PINK PANTIES ARE OVER!!! DO YOU MAGGOTS UNDERSTAND!!!!!!
Old April 27th, 2007, 08:18 AM   #10
lil666's Avatar
lil666 is on a distinguished road
Might try this as a replacement to wearing hood insulation.
http://www.b-quiet.com/hliner.html
______________________________
1999 Mustang GT Convertible
2001 F150 Harley Edition
2004 R6
Old April 27th, 2007, 08:34 AM   #11
zkid01 is on a distinguished road
I have seen this happen.... if i was you i would cut out the section that is rubbing.. so its still absorbing some of the heat. or you can take it off and replace it with something thiner.
BTW- lil666 if his stock is rubbing there is no way that a 1/2 think matt isnt going to rub.
Work Hard....Play Harder.
Old April 27th, 2007, 08:42 AM   #12
ATLmustang is on a distinguished road
you might be able to adjust the hood to sit alittle bit higher?
Old April 27th, 2007, 09:03 AM   #13
lil666's Avatar
I wasn't sure if it was the rubbing he was concerned about or the crap that the insulation left on the sc. i know old insulation can leave little crap and make stuff look like shite. That stuff would be cleaner, but your right, it's probably a bit thicker than stock.
That's why I'm a newb.
2004 R6
Old April 27th, 2007, 09:07 AM   #14
Wasnt knocking on ya... just pointing it out.
Old April 27th, 2007, 09:16 AM   #15
lil666's Avatar
I know.. it's cool. Good thing to note.
2004 R6
Threads Similar to: Hood Insulation
GT Hood Scoop on stock v6 hood. JSapit Visual 4 July 13th, 2007 02:57 AM
Hood insulation jrfan4life 99-04 1 June 27th, 2007 07:20 PM
Hood Insulation brad03svt Modular Mustangs 5 March 21st, 2007 09:21 PM
Cobra R Hood or Mach 1 or 2 Hood? Pick 1 of 4 hoods. Chris02 99-04 16 November 1st, 2006 09:46 AM
