Lucas Injector Cleaner - Forums at Modded Mustangs
post #1 of 19 Old March 21st, 2011, 09:02 PM Thread Starter
I have a procharger on my car running 10psi.
Any of you guys recommend running the lucas injector cleaner through the car?
jonnyspeed is offline
post #2 of 19 Old March 21st, 2011, 09:04 PM
02gtmustang's Avatar
I run lucas products in everything own and have ran the injector cleaner through alot... I like it
2002 GT mild bolt on car 13.4@101 sold
Looking for another 99-04 as we speak
Ironhorsemotorsports.com for all your ford needs!
02gtmustang is offline
post #3 of 19 Old March 21st, 2011, 09:14 PM Thread Starter
im just wondering if the injector cleaner will have some kind of negative effect if i get into boost or something..
and what do you mean by products ? what else do you run?
anyone else use lucas?
post #4 of 19 Old March 22nd, 2011, 11:12 AM
1999cobra92's Avatar
i personaly use sea foam, ive never tryied the lucas fuel products
Black and White Crew
Crew Member # 5
Check garage for mods and pics
if you Los Angeles and want to ride send me a text (323) 270-6827
0% Wheel hop, 0% broken parts, 100% wheel spin
1999cobra92 is offline
post #5 of 19 Old March 22nd, 2011, 11:25 AM
KB99GT's Avatar
While I can't speak for a boosted application, I can say that running 2 bottles through a car took the injectors from almost fully clogged to a nice clean spray on a 3800 v6. It does the job as far as cleaning.
KB99GT is offline
post #6 of 19 Old March 22nd, 2011, 01:11 PM
T-Lee. 30's Avatar
Send a message via Yahoo to T-Lee. 30
Good question I was wondering the same awhile back. I suggest put it in while you have half a tank and just take it easy on the gas until you run it close to E and still take it easy for a bit on the next fill up. Just try to stay out of boost if you dump it in. I have a centri and its easy for me to drive it daily and stay out of boost so that being said I guess it depends on the type of blower you have.
-03 GT(a) V1S trim 5psi, 338hp/358tq
-06 TBSS(DD) 439rwhp/439rwtq
-02 RC-51 (SOLD)
Iraq and Afghanistan War Vet . Convoys and convoy security. My Wife is also a Army and Afghanistan war vet.
T-Lee. 30 is offline
post #7 of 19 Old March 22nd, 2011, 01:17 PM Thread Starter
What brand did you run and how do you know it cleaned them out?
post #8 of 19 Old March 22nd, 2011, 03:58 PM
KB99GT's Avatar
Lucas of course, and it was on my mothers old car (since totalled by a big caddy) so I was able to pull em and turn it over to see the spray.
KB99GT is offline
post #9 of 19 Old March 22nd, 2011, 05:39 PM
blownstang's Avatar
I run 3M fuel system cleaner once or twice a year. Usually after winter. Havent used any with the supercharger yet but doubt it will hurt anything.
2003 DSG Mustang GT TR3650 - 411/403 with a Vortech S trim. Now back to stock.
2004 DSG Mustang Mach 1 4r75w - 436/377 unlocked. 452/386 locked. Intercooled Vortech V1 S trim, Circle D 4c converter, BCA valve body, VRS o/r x pipe
blownstang is offline
post #10 of 19 Old March 22nd, 2011, 06:33 PM Thread Starter
do you plan on it?
i would hate to use it then get some damn code...
post #11 of 19 Old March 22nd, 2011, 07:54 PM
limited's Avatar
I use techron in all my cars along with chevron gas, never had an injector issue
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
post #12 of 19 Old March 22nd, 2011, 09:48 PM
KB99GT's Avatar
I've heard good things about techron injector cleaner, but I haven't used it. I also run chevron unless im caught low elsewhere then ill run sunoco. (Not many chevrons in my area)
KB99GT is offline
post #13 of 19 Old March 22nd, 2011, 09:59 PM
WhiteVenom's Avatar
Send a message via AIM to WhiteVenom
Just leave it alone. All 9 cars ive owned have done fine without pouring a shit ton of additives like fuel injector cleaner or seafoam every year.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
WhiteVenom is offline
post #14 of 19 Old March 22nd, 2011, 11:52 PM
blownstang's Avatar
do you plan on it?
Yes will pick some up tomorrow. Just filled up with a full tank today. I always like to run a bottle through after that nasty winter gas.
post #15 of 19 Old March 23rd, 2011, 04:50 AM
The Mean Green
MATT02GT's Avatar
I run lucas in my cars.. its pretty much that or BG44k
Bolt on list in Garage...... MM Insomniac Crew
MATT02GT is offline
post #16 of 19 Old March 23rd, 2011, 10:53 AM
a.k.a. Racecougar
Tang Stang's Avatar
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Tang Stang is offline
post #17 of 19 Old March 23rd, 2011, 12:47 PM Thread Starter
yea i just pulled my car out of winter storage AND i put in a USED set of 42# injectors
Should i try it out or no?
post #18 of 19 Old March 23rd, 2011, 12:51 PM Thread Starter
and to be clear spending the money doesnt bother me so if it has no effect i wont be pissed off.
Only be pissed if it has a negative effect which im unsure if its risky or not.
post #19 of 19 Old March 23rd, 2011, 02:42 PM
WhiteVenom's Avatar
Leave it alone. Those should only be used for desperate measures. If runs good then leave it alone!
Again if your not sure it will mess something up and you dont care if it does nothing then why do it?
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Human Verification
