last piece for the track - Page 2
Old March 25th, 2011, 11:10 PM   #21
Nicos2001GT's Avatar
2001 MustangGT
14.039@100(60ft 2.2)
Nicos2001GT will become famous soon enough
Nothing major would happen if i just cut the caliper bar off completely?
Old March 25th, 2011, 11:11 PM   #22
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
many do it. JayC has been running for years that way
Old March 25th, 2011, 11:16 PM   #23
2001 MustangGT
Hm alright nice to know. Anyways i had a question about rims and tires. i wanted to run a 15x10 wheel but what would be the right size backing spacing and bolt circling? Dont really understand what it is either could you explain?
Old March 25th, 2011, 11:17 PM   #24
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
for a 15x10, the backspacing you would want is 6.5 and the bolt circle you need it 5x4.5
Old March 25th, 2011, 11:20 PM   #25
2001 MustangGT
Thanks, i got few more questions check you messages in a min
Old March 25th, 2011, 11:34 PM   #26
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
or you may need to run a spacer AND cut the bar off. i had to do both to fit my pro stars
cams + 150 shot
Old March 25th, 2011, 11:41 PM   #27
2001 MustangGT
If cutting the bar isn't enough ill grind the caliper and then run the smallest spacer
Old March 25th, 2011, 11:46 PM   #28
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
your gonna grind the caliper itself? have fun lol
cams + 150 shot
Old March 25th, 2011, 11:55 PM   #29
2001 MustangGT
Edit wrong order up toop..grind the caliper bracket,then if its still not fiting cut it off,then if not run the spacer
Old March 26th, 2011, 02:10 AM   #30
86er's Avatar
if you dont want a spare, fine a second COBRA spare wheel and mount a decent tire on the front, clears the brakes and doesnt stick out like aftermarket wheels
Just a truck
Old March 26th, 2011, 02:15 AM   #31
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
WhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really nice
Send a message via AIM to WhiteVenom
VW tires!
F8L or casper style.
Fact is they are not even rated for the weight of our cars but people do it anyway
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old March 26th, 2011, 11:52 AM   #32
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Originally Posted by WhiteVenom View Post
VW tires!
They are rated just fine for our cars. They are rated at 1201 lbs each, so together in the front they can handle 2402 lbs. Our cars weigh less than that in the front. The only thing about them is they have a low speed rating. Only rated to 118
Old March 26th, 2011, 12:26 PM   #33
11.463@121.50
saxmanJJ will become famous soon enoughsaxmanJJ will become famous soon enough
I didn't realize wheel spacers were not safe to use.
Is that really true?
I'm running 15 X FIVE inch wheels (Weld Draglites) up front on my GT. I went with the wider wheels since I felt safer running them on the street.
I had to go with longer wheel studs, and a thin spacer. I didn't hack on my calipers or brackets.
I realize that the Cobras are a whole other animal.
MM Bracket Racing Crew Member #5
Old March 26th, 2011, 03:12 PM   #34
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
ehh. I wouldnt use them if you dont have to. It puts added stress on axle bearings and just gives you another thing to break/twist. Biggest problem with them is they seize on (put on anti-seize) and people dont torque them dont properly.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Threads Similar to: last piece for the track
2 Piece Vs. 3 Piece Grille Delete tommy93 99-04 5 May 31st, 2010 06:02 PM
Two piece drive shaft or one piece? '05stangcrazy V6 Mustangs 0 July 21st, 2009 12:01 PM
2 piece vs 3 piece grill delete... whats the difference? motomack 99-04 9 April 6th, 2009 09:17 PM
rebuild kit or piece by piece viperlocc 5.0 Mustangs 15 January 27th, 2009 06:31 PM
2 piece Mach grill vs. 3 piece the20ftw 99-04 13 August 5th, 2008 08:22 PM
