2003 v6/2003 GT vert
![]() iTrader: 11 reviews
Gear installation
I'm about to order Ford Racing 3.73 gears for my gt but I want to know what all is a have to for the install. I really don't want to pay 325 for the kit but I don't want to half a** it either. My brother will be doing it but like I have stated, I just need to know what is absolutely needed along with the initial gears.
![]() 2003 sonic blue v6- 18" gianna's, straight pipes, 12" DC level 5 with DC 3.5 K 2003 sonic blue GT vert- Bout to be a Procharged P1sc BEAST
12.73@111.36
How many miles on the car? Mine had over 100,000 miles on it when I had gears put in so I went ahead and replaced all the bearings. If yours only has 30-40,000 miles I wouldn't bother.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
It only has 31,000 on it.
2003 Mustang GT
Its good insurance to replace all the bearings. You can go on Summit and buy the Rateck install kit. Let me see if I can dig it up for you.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
ok
#6 | |
2001 GT
![]() Rollin on 335 Steamrollers. |
so that's the only other thing i need for the install???
2001 GT
I'd go ahead and replace the trak lok clutches as well but that might just be me. They're gonna wear on you sooner or later
2003 Mustang GT
Here it is
Ratech 305K - Ratech Complete Ring and Pinion Installation Kits - Overview - SummitRacing.com This is from AJM's writeup, all the things youll need Metric set of sockets & ratchet – an impact can make things way eaiser/faster 3 jaw puller 8mm box end wrench hammer – doesn’t need to be anything special a simple nail hammer would wor low inch lbs dial type torque wrench ft lbs toque wrench flat head screw driver or similar 1 1/16” socket that is atleast half in drive and a big cheater pipe very thick/fat strudy phillips screw driver – you want a cheap junk one or a snapon/mac/matco/cornwell/crafts some brand that will swap out incase you bend or break it dial indicator 3 qts of fluid that doesn’t require friction modified 2 qts of fluid that does require friction modifier and 4oz of friction modifier 2 qts of oem/motorcraft fluid and a 4oz container of friction modifier you don’t need all of the above..just one of the options is fine BLACK rtv gasket maker -- I capitalized black due to its oil resistance A small telescoping magnet – not really needed but it can be useful White lithium grease in a can – not really needed but you can use it to prelube all your bearings Drain pain of some sort Carb or brake cleaner Dial caliper Freezer Oven Propane torch Install kit Set of inverted torx sockets
so i need the gears, bearings, and trak lok and thats it
2003 Mustang GT
Just the ring and pinion (gears) and install kit. Then the rest are just tools.
Ok thanks!
04 mustang gt
7.21 @ 98
i wouldn't even worry about the bearings at that mileage. i mean if you have the extra cash then sure go for it but at that mileage they should be in good shape. i had mine installed at about 40k...now have 86k, still goin strong
![]() cams + 150 shot |
I would recommend getting the carbon fiber clutches as an upgrade while ur there anyway, not much more
2004 2v GT--3.90's, t3650, H&R SS, 78mm TB, K&N CAI, steeda bump stop kit, HP Blues shocks and struts, soon to have a rear seat delete, light weight driveshaft. |
2003 Mustang GT
At that point though, you might as well just throw a 31 spline setup in it. She has low miles, shell be fine.
#16 | |
03 GT
![]() ![]() iTrader: 4 reviews
Do it! When I had my gears installed, I went ahead and got the bearing kit too. I think 75$ from AM.
![]() Vortech v2 si-TiAl Q- CXRacing- still need MAF
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
let me dig threw my majic box of extra parts im trying to give away and see what i can dig up for you to cut your cost down.
2003 mustang v6 ;)
slow
ok dug threw my spare parts junk and this is what i still have,
carrier shims, brand new in the package pinion shims, brand new in the package axle bearings, brand new in the package axle seals, brand new in the package gears will come with a new crush collar and pinion nut what you need pinion bearing, if your brother is not carefull removing he old one pinion seal with oil slinger gear marking compund rtv sealent if your interested you can have them |
#19 | |
Threads Similar to: Gear installation
| gear installation | beast5319 | Southeast | 1 | November 23rd, 2008 10:41 PM |
| 3.73 gear installation | bean185 | V6 Mustangs | 36 | October 23rd, 2008 11:58 PM |
| 3:73 gear installation | cobrasvt12 | New Members Introductions | 8 | February 27th, 2008 11:24 PM |
| gear installation | Rico-mofos | 99-04 | 29 | February 18th, 2008 08:03 PM |
| gear installation | 1BADSTANG | 5.0 Mustangs | 20 | October 8th, 2007 12:27 PM |
