4.6 compatability question
Old March 26th, 2011, 11:24 AM   #1
HamToast's Avatar
HamToast is on a distinguished road
I need some parts for my pony (specifically, MAF, MAP, TPS and EGR) and was told that the Grand Marquis uses the same motor and parts are interchangable. I also know several other fords that use the 4.6L modular motor (Crown Vic, F-150) and was wondering if those would be compatible.
Is it true that I can use those parts from a Grand Marquis, Crown Vic or F-150?
Old March 26th, 2011, 02:12 PM   #2
86er's Avatar
F150 has some, easiest is going to be finding a Grand Marq, Towncar or Crown Vic 2001 and newer. The three cars have the exact same engines as the mustang
Just a truck
Old March 26th, 2011, 11:31 PM   #3
HamToast's Avatar
The Towncar! I don't know how I forgot about that one but I knew there was another 4.6 I could use. Okay, so is it also true that I can't use the MAF because of specific programming for each of those vehicles?
Old March 26th, 2011, 11:50 PM   #4
86er's Avatar
I dont see why you couldnt, the tune is the only difference in the hp ratings. In 02 i believe the iat and maf were made to one, just make sure you figure that out from the town car etc and it should be the same maf
Just a truck
Old March 26th, 2011, 11:54 PM   #5
HamToast's Avatar
Thanks! I'll be sure to do some pre-junkyard researching and hopefuly find some good parts.
Threads Similar to: 4.6 compatability question
PCM Compatability sjr56 99-04 4 September 2nd, 2008 09:54 AM
5.4 to 4.6 compatability? 97S281 Modular Mustangs 7 August 21st, 2008 03:59 PM
compatability AnFking6908 V6 Mustangs 4 June 9th, 2008 01:42 AM
Fuel Pump Assy. Compatability Question menedu 99-04 2 October 18th, 2006 10:49 AM
Compatability of a v6 and a T5 TwinFox V6 Mustangs 4 July 5th, 2006 09:34 AM
