clutch kits?
Old May 15th, 2006, 06:22 PM   #1
dstang03 is on a distinguished road
clutch kits?
i need help i just put 10,000 in my engine and i need a better clutch kit can anyone help??????03GT thx Don
Old May 15th, 2006, 06:27 PM   #2
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
10 grand sounds nice, I dont know a thing about clutches because Im new to, but may I ask what mods you made, and if so what are they?
Old May 15th, 2006, 07:09 PM   #3
That's a pretty vague question that can produce a lot of different answers......how about some more info- intended application?, hp & torque figures (if available), car type and weight, trans type, rear axle ratio,tire size, etc..
88 Mustang Coupe
www.rickscarcare.net
Old May 15th, 2006, 07:12 PM   #4
Drgnracin72's Avatar
like he sadi all this info will help us out a lot
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old May 15th, 2006, 07:19 PM   #5
i have a 2003 gt
42lbs injectors
80mll mass
k&n cold air
fullyported c&c heads
forged hbeam rods
dss prox pistions
billet main support
forged crank
level 10 race prep block
typhoon intake
1 3/4 bbk headers long tube
x-pipe no cats
flowmasters
underdrive pullys
tuner
n52 anderson cams
Old May 15th, 2006, 07:20 PM   #6
manual trans 4.10 gears
Old May 15th, 2006, 07:31 PM   #7
i run a stage III spec and love it. its a bit on the heavy side for pedal pressure but its driveable! i wouldnt want to get stuck in traffic with it but it wprks well. never had it slip at all. it took awhile to get used to it but now i can dirve it like a regualr car and how much did that dss short block cost you? i am running bascically the same thing but with stage 20 race block. and 21cc pistons. and i dont see 10 grand in parts right there! and you know that you shouldnt run those underdrive pullies with that engine?
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old May 15th, 2006, 07:39 PM   #8
lol this is the second time i have bought heads and cams so i have spent 10,000 is mounth...i had dropped a valve so i couldnt reuse the heads.lol so i have to sue rpm oulet....buy anyway my long block was 8550.00and im sorry it is a race 20 block i have it here in front of me
Old May 15th, 2006, 07:40 PM   #9
why cant u use those pullys??
Old May 15th, 2006, 08:03 PM   #10
i cant remeber the exact reason but they really suggested you not use it in the papaer work i was given. what heads are you running now and are ou going to do a power adder? i only pain i think aroun 4700 for my completel bottom end! im going DOHC!
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old May 15th, 2006, 08:20 PM   #11
wow doch i was told its not worth the money??? you might have to tell me diff....lol...yeah if i was to go short block it would have been 3899..they have been the cheapest and fastest yet....i have no problems with those guys...im going spray for now then super...the engine can handel both but thats nuts haha...
Old May 15th, 2006, 08:47 PM   #12
who the fuck told you its not worth the money? youll make a lot more hp (if your blown) cuz the heads flow a whole lot more. so yeah youll make more power a whole lot easier and not ut as much stress on the bottom end. sounds good to me. you dont see many 800-900 sohc modulars(and if so extremely radical) but you see 800-900 hp on stock 03-04 cobra heads without any workso yeah they are a little more pricey but i plan on going twin turbo in a year or so so i am going o need the abilty to flow a lot more air!!!
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old May 15th, 2006, 08:54 PM   #13
yeah thats what i ment too much for what i want...im looking low 1osec car nothing big...so i will go super then n20 and i will be around 800/900
then i will have to change tranny
Old May 15th, 2006, 09:11 PM   #14
The spec Stage 3 is rated at 695ft/lbs of torque holding capacity and should work well for your car or they have a Stage 3+ which is rated at 800ft/lbs. You can view their full line at www.specclutch.com under the product section.
88 Mustang Coupe
Old May 15th, 2006, 10:08 PM   #15
your gonna have to boost close to 20 psi to get tha mower, so better have a damn good tune! and a good fuel system! im will make 800+ on the s/c setup and surely over 1000 with the turbo(s)
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Threads Similar to: clutch kits?
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 11:08 AM
Centerforce LMC Clutch Kits superbeef1000 Parts 2 May 3rd, 2007 01:56 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 03:33 PM
What is the difference between these clutch kits? Bizzac8785 5.0 Mustangs 4 February 20th, 2007 12:26 AM
Stage 2 Clutch Kits Or Just Clutch Kits itschristorres8 V6 Mustangs 3 September 24th, 2006 10:15 PM
