Look Ma! My First Post!
x pipe install help
whats up
ive got a 04 cobra and ive never worked on a car before, and i refuse to pay somebody to install the x pipe i just got. its a bbk off road pipe, and i want to put it on myself. however i need really clear install instructions to do it, and i cant find any. i know this isnt too hard to do, but i want to make sure i get it right thanks |
Install Tips
It is not hard to install the x-pipe or an h-pipe. You need certain tools however and a load of patience. For those who have not done work under their car like this, you will absolutely need the following. Others can skip this part. * A good floor jack (2 1/2 to 3 ton is preferred) you can do it with out it, but what a pain it would be! * Jack stands or tire ramps. Jack stands are preferred as you can get it up higher (you need it up about a good 1 - 1/2 feet depending on your own girth. ( I needed a lot of room...too many uh...sodas..ya..) * Liquid wrench or similar lubricant (for those of you with southern cars or cars that never see rain, snow, elements you will have a lot easier time then those whose cars see old man winter every year....corrosion is a tough customer ) anyone else may consider giving the local muff shop a few bucks to crack the stock nuts loose on the exhaust pieces with an impact gun (careful what you tell them. Most states its illegal to remove a working h-pipe, tell them you bought mufflers and headers if you need to. This is also why its better to do an x-pipe yourself) or you may try a breaker bar over your wrench. * A good socket wrench set with a long extension piece * Universal joint for the socket (you will not get at the nuts on the headers with out this) * DISCONNECT YOUR BATTERY, YOU WILL BE WORKING BY THE STARTER!!! (arcs are bad!) * I also recommend a chock stop by the back tires, the emergency brake and being in gear is not enough security for me. Make sure you get the jacks on a secure piece of the frame, out of your working area. Okay- here we go with the rest. Once the car is in the air, and you have all the tools, get under there with a flash light and just look around if you have never seen it under there very much before. Hose down all the nuts and bolts you will remove with liquid wrench or an equivalent lubricating product. Leave the o2 sensors in the pipe, but disconnect the wires coming out of it at the blue plastic connections. The front passenger side is a project to put it nicely with our any nasty words. I found it easier to go from the side, close to (but not in) the wheel well. The best bet is to get at it the best you can keeping the u-joint as straight as possible. Remove all the nuts that connect your h-pipe to the headers, and to the cat back exhaust pipes which lead to the mufflers. The last nuts to remove are the hanger nuts in the middle holding it up in the air. After this, you should be able to shake a little and pull the h-pipe to the ground. Careful, its heavy and you don't want to get squashed like a grape. Getting the old pipe down is the hardest part, I found cursing the old h-pipe and those who installed it helped, but what ever works for you. With the h-pipe out from under the car. Loosen all the o2 sensors but leave them in their holes. They each go directly into the same matching spots on your new x-pipe. I chose to put them in before I put up the x-pipe but its your choice, just don't forget where they go. With the Bassani x-pipe, you will need to remove the bolts at the muffler end of your factory h-pipe and transfer them to the new x-pipe (mine was used so new hardware may come with yours and you may be able to skip this, I don't know). This is a pain, but elbow grease and lubrication will get them off. These go on the same exact way onto the x-pipe. You should do this before getting the x-pipe under the car. Once you get everything prepped for installing the x-pipe you will most likely know what's next. Its pretty easy at this point. The x-pipe is lighter, gives more room to work, and should line up nicely. Check for the metal gasket on the passenger front side. It should still be on the header, but if it came off with you cats, you will need to put in on the new set. If it breaks, wash your hands and walk to the auto parts store and pretend you are buying a new gasket before you started the project, this way no one will laugh at you when you leave. As long as its in one piece you should be okay since these gaskets are re-useable. Hang the x-pipe on the hanger and loosely attach the nuts so it will be off the ground and easy to work with. Tighten the front nuts first at the headers as they are more important to fit early to ensure a good seal. Then connect your muffler pipes. You should always tighten the nuts a little at one end and switch back and forth until tight to bring each side of your connections together for a good seal. Make sure everything is tight and feel around each seal to make sure there are no gaps. You wont want to climb back under there when its on the ground and hot. Reconnect all your o2 sensor clips and you should be all set. Clean up your mess and fire it up! You will love the sound. If I have confused you (sometimes I don't make sense) feel free to email me with any questions and I will try to answer them. Good luck and enjoy!
Proud American
Okay soak the bolts that go to the header with some PB blaster and let it sit for a couple of hours if not over night. The reason for this is because those bolts are notirious for coming out. Then take out or unplug your O2 sensors. And then unbolt or unclamp the side going to the muffler pipes. Drop the midpipe. Now to reinstall use the header to midpipe gaskets that came with the pipe(if it didnt come with any inspect the old ones are reuse) Bolt everything up and plug in your MIL elimators if you went with an O/R pipe!
You might need a really long extension with a swivel socket! to get to the passenger side header to midpipe bolts!
Here's all the information you'll need, along with pictures:
http://www.fordmuscle.com/archives/2...ale/index.php#
1999 GT - CAI, Flowmaster 40s, MAC O/R X-Pipe, 70mm p&p MAC TB, p&p plenum, SCT Xcal2 running 93 octane tune, and heavy ass 20 inch rims. |
Threads Similar to: x pipe install help
| X pipe Install | MnrlGry01gt | General Tech | 7 | September 11th, 2007 01:58 AM |
| install on bbk h pipe | dadslx | 5.0 Mustangs | 12 | September 7th, 2007 04:40 PM |
| Header and X-pipe install | AndyG47 | V6 Mustangs | 40 | August 23rd, 2007 02:32 PM |
| HELP PIPE INSTALL!!!!! | 02steedagt | 99-04 | 26 | April 29th, 2007 11:58 PM |
| mid pipe install | o3gtdgs | 99-04 | 8 | December 23rd, 2006 04:43 AM |
