How much Boost to run on stock bottomend
Well decided im getting a brand new 2004 engine installed at local dealership 3yr 36k warranty and was gonna order a kenne bell 2.1 charger as it looks should have them both by july just what is safe with good tune for daily driven car with stock bottom end is 9-10psi too much? I want this setup to last me a lil while was hoping to run somewhere near 400-420wph on stock engine. My setup would be full exhaust with 75mm TB and KB 2.1 @ 9-10psi would this obtain my goal? and would it be safe for daily driver? My optimum goal is a low 12 sec street car.
RIDE: 2000GT- MODS: 2007 3 VALVE ENGINE AND MORE...... |
Proud American
9-10 psi is about where everybody says you shouldnt go any higher. But I am almost postive that the warrenty on the engine will be void if you put a KB on it. And yes that is a nice safe street car, but you will need suffeicent fuel for it!
#3 | |
Worked before when I ran Nitrous on my camaro had aftermarket lid that I tapped hole for nitrous line blew the intake manifold to pieces, so I removed all lines and put the stock lid back on some how I got away with it and the dealership replaced it but after I got the car back I opened up my glove box and my dumbass left the Nitrous button hooked up and in the glove box plain as day too I know the GM techs had to have seen it they just didnt care.
9 psi with a kb is what I'm running. You should hit your goal of 400-420 rwhp with it. Everything I read about the KB on their site says it can't void your warranty, but good luck telling that to ford.
Oh yeah. MAKE SURE YOU CHANGE YOUR PLUGS! lol
Mustangless atm 2006 2500 HD Diesel. Built allison trans and other goodies
#6 | |
yep learned that one.
Work Hard....Play Harder.
Threads Similar to: How much Boost to run on stock bottomend
| 17lbs of Boost on stock 2v | Garhfer | 99-04 | 22 | May 17th, 2007 09:14 AM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
| BOOST!!!!!!!!! | stangliter04 | The Clubhouse | 13 | July 4th, 2006 11:29 AM |
