water temp sending unit
Hi!
Can someone explain where the water temp sending unit is located at on my 2000 supercharged GT? I suspect it's broken since my autometer needle is not moving even if the engine is hot... I tought I found it but a mechanic told me that it was 99% chance it was the wrong sensor I found since it has 2 wires connected. He told me that the sensor just gave the temp to the computer and not to the gauges... He told me to look for a sensor with only 1 wire. I've looked around the engine room, but can't find it I'll be thankful for any answer that can help me locate it. [/img]
2000 Ford Mustang GT Supercharged |
Anyone??
Proud American
You have one in the intake! Ill post the pic! The highlighted part is where the coolant sensor is. I dont know if it is the one for the gauge or not! Hope this helps!
And this is not my picture! It is Caspers! Thanks Casper!
That's the one I thought it was, but a mechanic I know told me it's supposed to just have one wire connected... U don't happen to know how I can send some kind on signal to check if my autometer needle really works?
Proud American
Casper98GT is a ford tech! I would PM him he would have more of an idea!
Ok, thank you very much. I imported my mustang from California last autumn to Norway where I live, not many mustangs on the streets here... And not many people with much knowledge on mustangs
#7 | |
Wow Norway. You come to the right spot, this place has the knowledge and the people on this site do not mind sharing it and welcome to the site. |
Seems like there's alot of people with good knowledge about mustangs here, that' why I registered on this forum
MM's nicest mod, :)
i would guess that your autometer gauge is not hooked up cause if the stock one gets unplugged then the car will not start and not run right. For a mechanical or electrical gauge if you don't have another bung in the coolant crossover you have to buy a t-fitting so both the stock one and aftermarket can be plugged in.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
The autometer worked when I got the car, and sometimes it didn't. Now it's not working at all, so I guess it's hooked up. I belive it's something wrong with sensor, my Autometer or the wiring. Most likely the sensor or wiring
I have Autometer Instrument cluster Lunar series, it's electrical... If I knew wich wires for just the water temp gauge, it wouldn't be hard to follow the cables, but it's just 2 plugs with lots of wires on the back of the instrument cluster
Nice gauges BTW, i would follow the 2 wires coming off your temp sensor to make sure were they meet the rest of the harness everything is good. You could try replacing the temp sensor..those are the only 2 things i can think of.. as long as the rest of the gauges are working on the cluster..Good luck.
Work Hard....Play Harder.
MM's nicest mod, :)
oh i thought you had an aftermarket water temp gauge, you actually got the instrument cluster. thats a whole other story bud. That cluster hooks up just like the stock cluster and reads off the computer. Then everything is pretty much stock and i don't know why your isn't working anymore cause mine stock water temp reading did the same thing 3 years ago. Thats why i have an aftermarket 2 1/16 gauge. I guess you can try to replace the sensor.
I'll replace it if I only could find it...
If i could find it, it's not to hard to find out if the sensor is broken or not. I belive the sensor that MustangMatt96GT show in the picture above, is the one for the "brain" of the engine and not for the gauge...For those of you that are interested, I found a site where you can download Ford Service Manuals on dvd for free. Don't know if I'm allowed to post links in the forum, but if u PM me I can send it to you. I've downloaded it myself, but as I live in Norway I'm not that good at technical english
MM's nicest mod, :)
if you can't find it then something is wrong. look to the left of your altenator and you will see a 2 wire connector plugged into a sensor in your intake. BINGO there ya go
So it is the sensor with the 2 wires that's highlighted in the picture above that goes to the gauge then... I was told different from a mechanic friend of mine. Then I guess one of the wires go to the gauge, and the other to the cars computer :wink
its just a thermoresistor, find out how many ohms that is suppose to read and test across the 2 wires and see if its putting out the proper ohms.
post up that link man, we love links!
1986 Mustang GT t-top time piece! |
I'll look more into it tomorrow. Getting late here now, and I have to get up for work in 5 hours.
Here's the link: http://www.fordcds.com/
Threads Similar to: water temp sending unit
| water temp | coreyfitz | 94-95 | 1 | May 2nd, 2007 12:18 PM |
| Fuel Sending Unit | terribleonexx88 | 5.0 Mustangs | 6 | November 1st, 2006 10:29 PM |
| Installing Oil Sending Unit For 96 Mustang GT | gtdan | 96-98 | 4 | September 6th, 2006 06:40 PM |
| installing oil sending unit for 96 mustang gt | gtdan | 96-98 | 0 | September 6th, 2006 04:28 PM |
