LinkBack (1) | Thread Tools |
#21 |
99 limited edition vert
OP- just try it,it works well if you tps voltage is in the lower range just do not try to set idle with it, just adjust screw for tps to read ~1V. which is still within specifications, the iac will control it just fine.
If you read above post that is what it is doing, raising base idle to higher end of specs this is not intended to keep car idling, just for a stalling issue where rpms drop to low and iac does not react fast enough
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com Last edited by limited; April 2nd, 2011 at 07:04 PM. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/211622-tps-voltage-do-you-have-set-2000-gt.html
| Thread TPS voltage? Do you have to set it on a 2000 GT? | Forums at Modded Mustangs | BoardReader | This thread | Refback | May 5th, 2012 09:27 PM | |
Threads Similar to: TPS voltage? Do you have to set it on a 2000 GT?
| to much voltage at the TPS | 1OLDHORSE | 5.0 Mustangs | 19 | February 3rd, 2011 07:36 PM |
| TPS Voltage | Villain123 | 4V / SVT | 1 | September 30th, 2010 04:28 PM |
| no voltage. | crazyredneck | 5.0 Mustangs | 2 | September 1st, 2010 08:11 PM |
| O2 Voltage | Roush00 | 99-04 | 4 | March 16th, 2010 11:29 PM |
| max MAF voltage | WAVEBYE | 99-04 | 4 | September 27th, 2007 07:54 PM |
