#1 | ||
Still dropping
Forget to post this earlier. I did an oil change, and cleaned my Throttle Body and now my car doesn't quickly drop and rise (RPM Wise) at start like it use to.
But now, sometimes when I am at a light and come to a stop it'll drop a tiny bit, sometimes a little more. Also, sometimes when I put it back in gear it'll nearly stall. Any ideas?
RLY SRS
Theres a little gasket that someone made a post about on here that goes between your IAC and the Plenum...It is supposed to fix these issues...
Proud American
Also clean your IAC while you are at it!
or replace it.. it's cheap...$40...
![]() ______________________________ 1999 Mustang GT Convertible 2001 F150 Harley Edition 2004 R6 |
Did you get any cleaner on your MAS? cause if you did you need to wait tell it air drys... it can mess with allot of stuff. If that is dry then like Chris said there is a post about a little gasket that can cause this. Good Luck.
Work Hard....Play Harder.
#6 | |
![]() iTrader: 1 reviews
My car does this and my IAC is absolutely spotless, so i dunno what it would be
not sure exactly what you mean.... but in my car, when I get to a stop light, I'm usually about 950 rpms, and then after I stop and after a second or two, it drops to about 700-750.
Is this what yours is doing?? I just figured it was normal and not too serious.
"America is all about speed. Hot, nasty, bad ass speed." Eleanor Roosevelt, 1936
yeah, mine does that, and it also seems like its going to stall sometimes, it'll go down to about 500 or less, it does it when im idleing anywhere and ill be cruising along and put it in neutral and the rpms will stay up there for quite a while, i figured they should go right down., but what do i know
#10 | |
RLY SRS
#11 | ||
Yeah like mentioned above, I get the drop to around 750 and it sounds like she is gonna stall, then she'll jump back to 950-1k and stay and be fine.
No idea ?! My IAC was cleaned with the proper cleaner and it is way dry... it's spotless....
is there any way to adjust the driving idle?? sorry i dont mean to high jack i just have the same prob. and remember reading some where that on a tuner or a dyno tune that you could adjust the driving idle?
Is this happening on a auto or stick? I also found the post that ChrisJ was talking about above.. It deff. could be the problem that you are having. and idk were you are finding the IAC for $40, Cuase thats pretty low.. Oh yea and the post about your IAC is on the main page for the "how-to" section.
you can adjust the idle with a tuner.... i can do it on my diablo.
#15 | |
Threads Similar to: Still dropping
| Dropping in a V8 | nickp008 | V6 Mustangs | 24 | June 9th, 2007 12:28 AM |
| Dropping a v8 into my '01. | Dansby | V6 Mustangs | 18 | March 23rd, 2007 03:38 PM |
| Dropping A 5.4 In | built54 | V6 Mustangs | 17 | October 8th, 2006 02:16 AM |
| Dropping A 460 | tdurbin | 5.0 Mustangs | 6 | September 20th, 2006 09:52 PM |
| dropping my car..1in..1 5/8...2in? | itschristorres8 | V6 Mustangs | 21 | August 31st, 2006 08:53 PM |
