difference between speed caliber and the diblosport predito
im on americanmuscle.com and i see the combos for gears and speeed cal and the sct Tuner or the diblosport pred.
what is the differenbce betweeen the speed cal and the diblosport |
Proud American
Not much but the diablosport is just a little better. But I would call the speed shop you will most likey use if you ever use one and ask them what type of softwear they use. Most use SCT but Diablo sport is getting more and more tuners using it!
welll should i buy the type of tuners that will give you free tunes
also im just wondering i have a 02 gt mustang and i need a 4 10 gear and a tuner at a good price and easy to use any sugguesting if u could send a link tghat would b great |
Proud American
get the xcal from doug at www.bamachips.com! He is great and will send you free updated tunes for each mod you make! And then just get 4.10s!
#5 | |
#6 | ||
"America is all about speed. Hot, nasty, bad ass speed." Eleanor Roosevelt, 1936
Proud American
Well I didnt read it right! my bad! I posted a reply before the forums stopped working but it didnt show up so owel! neck is correct on this one! all it does is correct you speedometer where a diablosport will do much more such as change engine parameters!
Threads Similar to: difference between speed caliber and the diblosport predito
| Difference In Speed From 05 to 07 | 07stanggt | 2005 - 2010 | 64 | May 14th, 2009 07:59 PM |
| Any difference? | ma67cpe | 99-04 | 4 | September 22nd, 2007 10:56 PM |
| Brake Caliber | locknest | V6 Mustangs | 8 | May 3rd, 2007 04:34 PM |
| difference between these two | rymasm | 2005 - 2010 | 1 | March 6th, 2007 10:38 AM |
| Difference? | ScreaminYellow05 | V6 Mustangs | 6 | January 7th, 2007 03:32 PM |
