2004 Mustang GT vert
426 rwhp, 446 ft-lbs
up $hit creek with my intake manifold
Hey guys, need ideas quick. I was installing my new TB/plenum setup today, and as I was bolting the plenum down to the intake manifold, one of the bolts got cross-threaded, and the metal threads that are glued into the plastic manifold came unglued and came out stuck to the bolt. Threads are ruined, otherwise I would just try to epoxy/superglue them back in there. And I can't put my plenum/TB on my car. Was thinking of going to Auto Zone tomorrow and looking for a helicoil that I can loctite/epoxy into the manifold that I can screw into -- that seem like the best plan on action to you? I really don't want to buy a new intake manifold. More than that, I really don't want to have to put it on.
2001 YUGO GT
You aint gonna belive this shit, but when I slaved for AZ in Memphis the brothers showed me all knids of things. And if ya can't fix it with JB Weld than it is junk. Ya might try it, the brothers sware by it!
#3 | |
yea JB is the best. i use it on everything. it bonds good to plastic. when i laid my CBR over i Jb welded the cracks then sanded it down and panited it. its good shit
JB is the king. This may not help you but but I used it in side my dryer the other day and I have to say its the best.
I would get yourself a tap-and-die kit and rethread the hole as it is, w/out the jb weld. then just use a slightly bigger bolt. it will be a lot cleaner and a lot less room for error IMO.
"America is all about speed. Hot, nasty, bad ass speed." Eleanor Roosevelt, 1936
go to walmart look in the hardware section where they keep glue and tape. There is a plastic weld kit. it looks like a double seringe . I swear by it on plastic. Before I got the aluminum cross over intake put on my car, I mixed some of that up and rubbed it into the crack on the intake and the damn intake never leaked another drop! I can get you the nut part that is stuck on your bolt if you need one. I has a spare intake laying around I can get it out of for you.
1986 Mustang GT t-top time piece! |
Update: I JB welded it and it held together. Got the plenum/TB mounted, and when I start it up, it starts fine and idles fine, but when I had my buddy kill the engine, and I was listening with the hood up, there was kind of a faint hissing sound that lasts 1-2 seconds. Is that normal or is that a vacuum leak? I guess I never really listened to my engine with the hood up and had someone cut it off before, so I don't know if that short hiss is normal or not.
Proud American
This is normal! This happens everytime I shut off my car!
#10 | |
#11 | |
#13 | |
anytime man. I dont mind helping any guys here out when i can. I know what its like to be in a pinch like that, and some of these guys have helped me man. Thats how I like it.
#15 | |
2001 YUGO GT
So now my next question is: after this install, the idle comes down really slow when I rev it. Anyone know what could be causing that, or is it just normal? Does it have something to do with the IAC? My car idles smooth, and it doesn't try to stall when I put it in gear or anything, the RPMs just come down really slow.
Ahh, I did some looking around on the forums here, and it sounds like this is a common problem with our cars -- the RPMs come down slow so the engine has more time to burn off fuel for emissions reasons. I'm going to look into an IAC restrictor plate, but probably not until I get tuned. It's just annoying you know, I pull up to a stop light, and the RPMs stay up for a couple seconds, it sounds like I don't know how to drive.
haha yeah. Its a common problem.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
dude your just lucky you didnt "blow the welds on your intake" -vin diesel... im sorry im bored and find that quote hilarious
Threads Similar to: up $hit creek with my intake manifold
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 6 | November 20th, 2010 11:20 PM |
| Oil under intake manifold?? | lil666 | 99-04 | 4 | May 17th, 2007 07:56 PM |
| Intake Manifold | terribleonexx88 | 5.0 Mustangs | 16 | October 19th, 2006 11:54 PM |
| intake manifold | ayyubam2002 | General Tech | 2 | July 9th, 2006 12:13 PM |
