1998 Z28
Ball joints?
I know minimal about suspension and I hear a squeaking when I turn and when I hit bumps and I know it's the ball joints my question is can i use a grease on these and if so where can I find some!
Unknown
i dont think there are any grease fittings on our cars. i could be wrong tho.
no there is not. how do you know its comming from the ball joint? a way to tell if its bad is put the car on stands(let the wheels hang) get the tire about 2 inces off the ground. put a barr or something under the tire and raise it up and down while watching the ball joint. should be a little play verticaly but not alot.
1998 Z28
Well when I have the car sitting still and Ill turn the wheel right to left it squeaks if i hit a bump it squeaks if i push the hood down repeadetly to make the car move up and down it squeaks and when it rains the squeaking stops!
Unknown
try checking it the way i told you and let me know if it moves a bunch. with what you done it could me isolators, springs, struts, camber plates, ect.
1998 Z28
No it's not moving so if it's not the ball joints could it be anything with the steering column?
Unknown
2001 Mustang GT
14.51
my car is doing the SAME EXACT THING bro. over the course of like 3 to 4 days it went from smooth and no noise to, squeeking while turning squeeking when hitting bumps, both when im sitting still and driving. i brought it to my mechanic he said sounds like balls joints but lemmie take a look... lifted car with jack and used the crowbar technique described above. he said ya its definately ur ball joints. he said the reason im juut startting to hear it so quick is, i live in mass and we are jsut coming out of winter, but we've had a really slushy wet winter. well the last 4 days have been beautiful and the car is really getting its first dry-out since ive owned it. the dry weather is unmasking the old ball joints that have been lubed by wet weather all winter.
and heres my question, does $250 sound like good price to have lower and upper done on both sides? that was his offer |
#8 | |
1998 Z28
Unknown
#10 | |
1998 Z28
oh well maybe I can get a big NASTY mechanic to help me grease them up nicely
Unknown
2001 YUGO GT
BWAL09 your as bad if not worse than me. And no, no help greasing your ball joints here either.
But do get the joints from a 04 Cobra the have a zert fitting. Ya can do it yourself AZ or advance can loan you the splitter tool. Good days work fro the home mech.
#13 | |
Mod of the Year '11
2021 Mustang V12
Quad Turbo with nawz
#14 | ||
2001 YUGO GT
#15 | |
Boost gets you laid
woah woah woah.. before you do ANYTHING to your ball joints. check your TIE ROD ENDS!!!! mine was squeaking really bad so i pulled the tie rod off the spindle. (theres a cotter pin through the nut) i then moved the tire and turned it left and right and let the car down and pushed down on the bumper, no noise. so i inspected my tierod end and sure enough, the grease was all dried out and it was squeaking. so i took a screwdriver and pried the rubber away a little bit and squirted the grease gun in there a few pumps. the noise is gone now! make sure its not your tie rod ends before you get into ball joints. they are non-serviceable but you can get some grease in there if you work it a little.. you can replace them yourself and you can get new ones off ebay for cheap. i missed a bid on one the other day it sold for $3 brand new.
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
all aftermarket balljoints for the mustang come with grease zerks no need to buy cobra balljoints.
No you cant drill a hole and add a zerk. Your mechanic is a fuckin dumb ass or you are one because your car doesnt have upper balljoints! Those prices are out of this world. Go buy you some balljoints from a parts store for $20-$30 a piece and you only need 2. one for each lower control arm. Then put them in yourself. I can do the balljoints myself on both sides in about an hour - hour/half. If you never done it I would say 3-4 hours tops once you figure out how to use the tool to get them out and back in. Then have it realigned.
1986 Mustang GT t-top time piece! |
#18 | |
2001 YUGO GT
wbaker@johnbleakleyford.com
#19 | |
2001 YUGO GT
W.P> wbaker@johnbleakleyford.com
#20 | ||
Threads Similar to: Ball joints?
| Changing ball joints | 8A_Honda | 5.0 Mustangs | 24 | May 15th, 2010 07:58 AM |
| U-Joints | zkid01 | 99-04 | 4 | May 23rd, 2007 02:36 AM |
| ball joints | winez31 | 96-98 | 1 | January 7th, 2007 02:35 PM |
| U-Joints | Milner62 | 5.0 Mustangs | 3 | August 11th, 2006 02:36 PM |
| Ball Joints On Lower Control Arms | OTreborO | General Tech | 0 | May 5th, 2006 05:21 PM |
