nitrous express
Old May 5th, 2007, 03:14 PM   #1
mrnewall is on a distinguished road
nitrous express
hey everyone i just got the Nitrous Express Ford EFI Plate System (96-04 2V GT)
off american muscle site I also got a perdge kit and remote opener. Anyone have this kit? I know it comes with upto a 150 shot jet. Could you run this shot on your car without having to change internals. I have a full exhaust and knn intake for now. Also how noticeable would this be hopefully it will put me back in my seat like a turbo kicking in. Iv been in a corvette with a 75 shot zex dry however and it was not that noticeable.
I will be in the west coast of Canada and its a very mild climate, is a bottle heater esensial as they are quite pricey and will be left quite poor after getting this installed etc
Cheers everyone WRITE BACK SOON!
steveo
Old May 5th, 2007, 08:56 PM   #2
Drgnracin72's Avatar
the bottle heater is needed becasue if the pressure in the bottle is not right, it wont make the right power. 100 shot is as far as you need to go on your stick shortblock. and also you must get a tune for it.
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old May 5th, 2007, 09:02 PM   #3
superbeef1000's Avatar
congrats on the new kit post u[p some pictures when your done with it
Old May 5th, 2007, 09:06 PM   #4
FOR POINT SIX's Avatar
FOR POINT SIX is on a distinguished road
listen to what drgnracin72 says, get a tune.
Old May 5th, 2007, 09:51 PM   #5
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
i am running that kit on my car and running the 100 shot. you will definately need a tune and new spark plugs in the car. try NGK TR6 gapped at .035
Old May 5th, 2007, 10:15 PM   #6
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
bottle heater a big plus, needs to keep pressure around 950psi. i was running a 100 shot on mine and i am moving up to a 125, all on stock internals. i have on nos system with a n/x plate, digital window switch, purge, pressure controled heater, and 2stg colder champion plugs. off a 100 shot i dropped a second off my 1/4 with a little traction issue.
Old May 6th, 2007, 02:27 AM   #7
by a tune do you mean just a service? Ie oil change checking compression that kind of thing? Also why do i need to change my spark plugs if they work well? ps what should i change to?
thanks steve
Old May 6th, 2007, 02:32 AM   #8
Proud American
MustangMatt96GT's Avatar
No a tune means get it on a dyno and sombody will tweak your computer to safely spray! Also you will need to run colder plugs so that you dont get detationation! And I have no clue on what plugs to run because I have no expirence with nitrous!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old May 6th, 2007, 03:50 AM   #9
ngk tr6 gapped at .035 will work fine for what your wanting to do. and youll have to keep good plugs in it because nitrous is hard on them. as for tuning, you need to take it to a tuner and they will tune for the nitrous. usually they will pull about 2-3 degrees of timing all the way across the board to make a 100 shot safe
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old May 6th, 2007, 04:12 AM   #10
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 7 reviews
there are a few people safely running the 125-150 shots on the stock bottom ends... but with you just starting out i would run a 100 shot.....
READ THIS
http://forums.modulardepot.com/power...q-nitrous.html
TT Build in progress.......
Old May 6th, 2007, 07:45 AM   #11
thanks very much guys hopefully you have saved me from blowing my engine ill get some pics once installed
Threads Similar to: nitrous express
nitrous express plate system Modern_Muscle 2005 - 2010 6 September 26th, 2007 01:35 AM
nx express srt_eater935.0 5.0 Mustangs 11 April 3rd, 2007 12:12 AM
Nitrous Express Install Videos 99mustang232 General Tech 1 November 27th, 2005 08:20 PM
