![]() iTrader: 1 reviews
clutch question
this is a pretty noob question but meh
typically if you get a higher rated clutch, does the pedal get harder or softer to push or does that matter on something else? |
Proud American
Depends! But you might feel only a little difference! The centerforce dual disk is easier than stock! But a spec might be a hair harder!
My spec stage II does not fell any different than my stock clutch. But when you are in a parking lot or any where you are trying to drive slow it is very hard to just slip the clutch. It is ether 100% grab or nothing, a lot like a on off switch.
Proud American
Yeah my King Cobra clutch is like an on off switch too! It is a lot harder to make smooth if you are going really slow!
mine jerks lol
or i go to start from a stop and its around 1000 rpm when i let out the clutch and then it goes to stall so i push in the clutch and then all of a sudden it revs up to like 2500, its fucked.
I had the King Cobra in my last Fox, and it was not as bad as this spec is. But I will always give up some slow speed comfort for the relief of knowing the clutch will not slip.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
i had a king cobra that was a pos, i went to a spec stage 3 and love it. it is a firmer clutch, but is a lot stronger than what i need.
#8 | ||
Yeah Stage II on the newer stang feels 99.9% like stock, but if I am starting out real slow from a stop light, or at a drive through...
It's kinda rough, I'm either in gear, or I'm not, there is no slow bite.
Threads Similar to: clutch question
| clutch question | KhaosGT | 99-04 | 10 | November 5th, 2007 09:00 PM |
| New Clutch question... | Onemanzu | V6 Mustangs | 9 | August 14th, 2007 09:26 PM |
| clutch question | El_Cangri | V6 Mustangs | 9 | May 3rd, 2007 09:53 PM |
| 05 GT Manual Clutch Question | THnCS | 2005 - 2010 | 0 | February 9th, 2007 03:44 PM |
| Clutch Question | o3gtdgs | 99-04 | 8 | November 16th, 2006 12:50 PM |
