idle question
Old May 6th, 2007, 05:08 PM   #1
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
idle question
i've noticed that when i'm in normal stop and go traffic, my idle rpm is really erratic. it doesn't spike, but it does drop to about 500 rpm. the weird thing is, it only happens when i'm running the a/c or the heat. car's not throwing any codes, and i've cleaned the IAC a few times. i've checked for vacuum leaks and haven't found anything. ideas, anyone?
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old May 6th, 2007, 05:46 PM   #2
Proud American
MustangMatt96GT's Avatar
My best guess is that the A/C is putting a strain on your engine. Mine actually revs higher when I have the A/C on or the Heat on! Maybe somebody else will pipe in!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old May 6th, 2007, 06:01 PM   #3
Ryno's Avatar
Ryno is on a distinguished road
Re: idle question
mine does the same thing... i think its normal...
Ryno
www.myspace.com/ryno5700
Old May 8th, 2007, 02:12 PM   #4
spero's Avatar
spero is on a distinguished road
my car does the same thing more so a sudden stop or after long driving.
2000 black mustang GT W CAT BACK
Old May 8th, 2007, 02:52 PM   #5
DrHolliday is on a distinguished road
Re: idle question
Mine does the same thing when the A/C or the defroster is on. ( when you have on your defroster it runs the A/C pump too )
Its normal, just the engine bogging a little bit from the strain of the A/C pump.
Old May 8th, 2007, 03:36 PM   #6
zkid01 is on a distinguished road
Its completely normal.. your AC is going to put a strain on the engine.. so its going to pull down your rpms a bit at a stop. No worries.
Work Hard....Play Harder.
Old May 8th, 2007, 04:14 PM   #7
02steedagt is on a distinguished road
Send a message via AIM to 02steedagt
+1 normal. mine does the same.
"America is all about speed. Hot, nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old May 10th, 2007, 02:03 PM   #8
Resident Bubblehead
00vabchgt's Avatar
well, got this one figured out, too. i found out (by browsing through the owner's manual of all things) that if the battery is disconnected, you're supposed to start it and let it run with everything off for a few minutes and then with the a/c on for a few minutes so the computer can "relearn" the proper idle. this turned out to be tied in to the problem i was having where the car wouldn't start. all this over a battery that was going tits up. it needed more time to build enough power to turn the started. old battery out, optima battery in, hopefully no more issues. the gremlin hath been slain.
Military Crew
MM1 (SS)
US Navy Veteran
Threads Similar to: idle question
Idle question dadstoys2 5.0 Mustangs 7 August 24th, 2007 01:15 PM
small question about dropping idle flattusmaximus78 V6 Mustangs 4 July 15th, 2007 08:48 PM
Idle question? dmachine22 99-04 4 April 14th, 2007 11:12 PM
Newbie Question - Hanging Idle unitl stop Murago 5.0 Mustangs 10 August 2nd, 2006 11:17 AM
94 GT idle question... WVSNS& 5.0 Mustangs 1 February 10th, 2006 03:12 PM
