got any tricks on how to fix this?
Old May 7th, 2007, 06:43 PM   #1
crappy_head's Avatar
2001 GT
crappy_head is on a distinguished road
Send a message via MSN to crappy_head
when i screw my shifter knob in it will not center it self. its screwed in all the way in the pics. any tricks or tips on how to fix it? thanx
Old May 7th, 2007, 06:45 PM   #2
Proud American
MustangMatt96GT's Avatar
All you have to do is play with it! Try starting it at a different position! It normally takes me 3 times to get it correct!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old May 7th, 2007, 07:08 PM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
+1
this is great sig material btw
Old May 7th, 2007, 07:09 PM   #4
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
try washers? If they won't stop if from the bottom or stick out too much, you can put a nut on it and run it all the way down, and see if that helps out.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old May 7th, 2007, 07:10 PM   #5
DrHolliday is on a distinguished road
If all else fails, get a nut that fits on the shifter threads, put the shifter where you want it, then use a wrench to tighten the nut against the shifter to keep it from moving.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old May 7th, 2007, 08:04 PM   #6
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Put some loctite on it and screw it to the desired position and let it set up over night.
Old May 7th, 2007, 08:30 PM   #7
2001 cobra
01whitecobra is on a distinguished road
Send a message via AIM to 01whitecobra
you are missing a jam nut. mine was missing it too.
Threads Similar to: got any tricks on how to fix this?
Any tricks for finding exhaust leaks?? 96mystic Modular Mustangs 19 October 2nd, 2009 02:07 PM
Craziest car tricks/tips 707Stang The Clubhouse 3 October 15th, 2007 05:19 PM
SEX TRICKS Racerchik02 The Clubhouse 349 July 31st, 2007 12:33 AM
need some tricks for my 1997 v6 mustang coffecake V6 Mustangs 30 February 11th, 2007 09:09 PM
Carb. Tricks shockashark 5.0 Mustangs 3 November 11th, 2006 03:49 PM
