2003 Mach 1 Mustang
sry im a noob dont know that much about cars
What would i have to do to make a stang handle better Springs sway bar?
1999 Mustang GT
i would think springs and wider tires would be a pretty good start
i'll have some pics here soon.. |
2003 Mach 1 Mustang
so changing springs will work? what i heard is you can also change or remove the sway bar and that will help it out also? is this true o_O
![]() M.M. MACH1 CREW Member 7 |
Proud American
Donot remove the sway bars if you want better handleing. But changing the springs will lower the center of gravity and there for give you better handleing!
2006 Mustang GT
Upgrading your rear axle, & full suspension is your best bet if you want great handling, but springs will work for now, until you add more power.
OK if you want better handling your going to want to put a set of springs on first ( i would also add some caster/camber plates at this time).. this will lower your center of gravity and improve cornering. New struts and shocks, should be added at some point. Next some upgraded sway bars.. front and rear will improve body roll. And a front and rear strut tower braces will also stiffen it up.. Another option is to put a set of full length subframe connectors on the stang.. You might also want to put on some upper and lower control arms in the rear. And of course some wider rims and better tires will give you improved handling.
If your getting into more serious road racing your going to want to go with a coilover setup, instead of springs (this will allow adjustable ride height..) A aftermarket K member and panhand bar. Along with the other stuff mentioned above..And last you are going to want to add a bump steer kit so you dont have trouble controling the car under hard cornering. Brothersperformance is a great place for stang handling.
Work Hard....Play Harder.
2001 YUGO GT
Add 04 Cobra front lower arms, there like 128.00 a pair gives the car that agressive Cobra stance. //wayne baker and Bleakly Ford will help you out
Both opf these companys are good to work with wbaker@johnbleakleyford.com And: Bullitt Mustang Suspension Kit - 94-04 Mustangs View On Line Price $509.95 Josh @ http://www.stangsuspension.com/store...namicIndex.asp
2003 Mach 1 Mustang
so wats the cost of everything estamated?
check out some steeda parts if you're looking for great handling. www.steeda.com
you can have a VERY solid suspension set up for about $2000 or less.
"America is all about speed. Hot, nasty, bad ass speed." Eleanor Roosevelt, 1936
I will try to put some prices together for this stuff.. and post back.
2003 Mach 1 Mustang
thanks bud i would like that
ok here are some links from steeda.com they have great products for handeling..
Subframe Connectors http://steeda.com/products/full_leng...connectors.php Strut Tower Brace (front) http://steeda.com/products/4130_allo...trut_brace.php Strut Tower Brace (rear) http://steeda.com/products/rear_shoc...r_brace_99.php Steeda Lowering Springs http://steeda.com/products/steeda_hi...on_springs.php Or you can start with these packages!! that way you get it in chunks and decide which one gives you what you want. http://steeda.com/products/sn95_part...nsion_paks.php Hope this helps some. Just do some searching around the internet.. Steeda, and brothers performance, american muscle are a few good places to start.
sorry to hijack your thread, but does my '02 GT have IRC?
2002 Mustang GT. 18" Shelby Torque Thrusts w/Mach 1 lip, Cobra Front End, Short Throw, K&N filter. Nothing impressive as of yet, but I'm working on it. |
#14 | |
2006 Mustang GT
I think you meant IRS. And no you don't have it. Only the newer Cobras do that I know of. |
Proud American
99+ cobras have it and I dont know about the newer shelby!
#16 | ||
2003 Mach 1 Mustang
Who the F*$&!()@*$ you think you are to hijack my trend......
j/p
lol. Hey, at least i said sorry, lol.
Threads Similar to: sry im a noob dont know that much about cars
| Noob with cars. | adpr_02 | V6 Mustangs | 44 | September 18th, 2007 04:01 PM |
| I still dont get it | JASonic | V6 Mustangs | 35 | May 25th, 2007 03:36 PM |
| AWD cars dont own RWD | 02ponypackage | The Clubhouse | 32 | April 14th, 2007 06:35 AM |
| dont know what to do | 9stang1 | 5.0 Mustangs | 1 | January 16th, 2007 08:54 PM |
| dont no wat it is | Rolis | V6 Mustangs | 21 | December 28th, 2006 11:06 PM |
