well the 4.10's are in and...
Old May 11th, 2007, 08:34 AM   #1
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
i went ahead and looked through the 4.10's discussions, and went ahead and tried them. personally i hate them! they would be great n/a but i think they suck on the bottle. i had to raise the rev limiter 300rpm just to get through the traps without bouncing it. my 60ft - 1/8 mile arent any better, and actually i cant even get back into the 7's in the 1/8. i am still fighting traction issues on my e.t. streets, but i have been for a while now. just thought i would throw this out here for you guys to debate on, or whatever you want to do.
Old May 11th, 2007, 08:36 AM   #2
mrnewall is on a distinguished road
what shot are you running? How did they change the car wile on the bottle? Did it just make you find it hard getting grip? Dont you think if you put some big slicks on your bad boy it would be faster with the 4.10s at taking off
wb or message me steve
Old May 11th, 2007, 08:48 AM   #3
bigbadwollfff04's Avatar
bigbadwollfff04 is on a distinguished road
i had the same problem this week at the track too, my times are horrible too with the 4:10's gonna be adding sand bags in trunk so hopefully i can launch!!
Aww, did I step on your poor little bitty ego?
Old May 11th, 2007, 09:15 AM   #4
zkid01 is on a distinguished road
sucks to hear man.. hope times get a little better once you get used to them.. but your not the first ive heard complain about that. So maybe somone with a simular setup will read this and take some consiteration.
Work Hard....Play Harder.
Old May 11th, 2007, 10:19 AM   #5
Beaterz is on a distinguished road
I have all bolt on's and a 100 shot of the gass with 4.10's and I love them! Do you have a window switch on the bottle? Now you can start pumping money into traction upgrades like me! Good luck man...
Old May 11th, 2007, 10:57 AM   #6
banned is on a distinguished road
this is like saying i wish my car was slower so i could control it better, the problem is not the gear.
Old May 11th, 2007, 11:10 AM   #7
zerofx150's Avatar
2003 GT
13.6 @ 101
zerofx150 is on a distinguished road
Send a message via AIM to zerofx150 Send a message via Yahoo to zerofx150
launch in 2nd gear, my first gear is useless with 410s and i have yet to try it with nitrous.
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports.
Old May 11th, 2007, 11:41 AM   #8
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
+1 on that.
I run 4.30's in my Mach with a 125 shot. I don't know if you have considered getting a progressive controller, but I think that would help you on launching. I don't have anyting to compare the 60's to pre-gears, but I can consistently get the same or better 60's with the N2O vs. without it.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old May 11th, 2007, 12:44 PM   #9
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i am cutting a 1.877 60 on the bottle with 4.10's, and 1.73 with the 3.55's. off the bottle i cut a 1.822 on my n/a tune. the window switch is set at 2200-6100 to get my launch lower to help with the traction and to carry me through the traps. i run mickey thompson e.t. streets so i can qualify in bracket classes since they require a d.o.t. tire. i've tried 11-16 psi, launch in different rpm's, and so on and so on. i am up to a 125 shot and am considering a progressive controller pretty soon.
Old May 11th, 2007, 12:50 PM   #10
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
it may be just me, but I was told that I shouldn't spray below 3000 anyway. My window switch is set from 3000-6200. I pretty much don't spray in first gear and then floor it in second with the WOT switch.
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Old May 11th, 2007, 01:09 PM   #11
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
well, below 2500 rpm there is a risk of hurting rods but that is just a precaution. a friend of mine has an auto and has been spraying from 2100 without any type of problem.
Old May 11th, 2007, 01:18 PM   #12
2200 is way low, 3k -3500k try that and you 60's will improve
Old May 11th, 2007, 01:47 PM   #13
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
iTrader: 10 reviews
with the 410's, i am not in 1st long enough to really spray and then when I shift I am above 3K anyway. just my theory.
Old May 11th, 2007, 01:59 PM   #14
03 R Code's Avatar
Same here with the window switch. It's hard to stay out of the nitrous in first gear but it's just something that I had to work on. My window switch is set up at 3k - 6,200. I launch higher than 3k anyways and just have to be concious about where my foot is on the throttle. I've had a couple of 60's that were extremely good for me, a 1.70 and a 1.72 without the nitrous, but I haven't run the nitrous in a few months at the track... My best with the nitrous is 1.80 and 1.82. I know that I can get lower 60's with just better driving skills.
I really feel like your window switch is set too low for activation anyhow, but I'm no expert on it. I would recommend either moving it up in the rpm's or going with a progressive controller. I have not yet installed mine so I can't give any real opinions on it yet, but I've got high hopes on it!
Old May 11th, 2007, 06:23 PM   #15
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
just because i have it set that low, doesn't mean i am launching that low. i am launchinag around 3200 or so. the higher i launch, the more i spin. i have to work at trying to keep it under control.
Threads Similar to: well the 4.10's are in and...
4:10's for a V6 98mustang V6 Mustangs 50 August 10th, 2007 12:00 PM
10's ? Regency 2007 2005 - 2010 9 June 14th, 2007 04:06 AM
4.10's slightly stoopid 96-98 2 May 20th, 2007 11:20 PM
0-60 after 4:10's flattusmaximus78 V6 Mustangs 71 May 14th, 2007 12:05 AM
