Cobra brake conversion kit?
Old May 11th, 2007, 07:15 PM   #1
2003 Ford Mach
Traveling at the speed of a photon
chris1 is on a distinguished road
are they worth putting on a 01 gt? do they increase stopping power? whats a good price for the whole kit? and does it require any heavy modifications or is it basic?
Old May 11th, 2007, 07:44 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
I know whos your refering to... :wink
but as far as it goes IMO
yes you stop better.
all you need is:
the Cobra calipers
the Cobra brackets
the Cobra rotors
it's pretty basic man.
Old May 11th, 2007, 10:40 PM   #3
zkid01 is on a distinguished road
all you need is:
the Cobra calipers
the Cobra brackets
the Cobra rotors
+10, i would say it is worth it. And its a basic switch out.
Work Hard....Play Harder.
Old May 12th, 2007, 02:51 AM   #4
ZOOTOXIN's Avatar
ZOOTOXIN will become famous soon enough
I think you need 17" rims at least...not sure but you should check. You will have to paint rotors-they arent zinc coated and will rust immediately.
The best price I found is at this linjk...
http://blueovalindustries.bluekeyinc...p?pid=99011776
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
Old May 12th, 2007, 03:39 PM   #5
lil666's Avatar
lil666 is on a distinguished road
I did a few months ago. Big difference over my 99 GT stock.
I went with stangsuspension, as they had a whole kit with everything for a decent price. And can get nice drill and slotted rotors
You DO need 17inch or larger rims. (Get rid of the spare, as it won't fit after this.)
The install was pretty easy. I had a problem bleeding mine. Spend an hour or more trying to bleed the system. Pedal kept going to the floor, no firmness. I took it to ford, and they had problems bleeding... until they bled the master cylinder. Then all was well. Don't know why I had to do that, as all I took off were the front brake lines to put on ss ones. But just something to keep in mind if you have problems bleeding.
______________________________
1999 Mustang GT Convertible
2001 F150 Harley Edition
2004 R6
Old May 12th, 2007, 03:42 PM   #6
lil666's Avatar
Oh... one other thing to note. The rear bracket kit was very hard to come by. If your doing the rears, make sure you check with whomever you purchase from to make sure they are in stock. Last I knew, Ford was back ordered nationwide for the bracket kit.
2004 R6
Old May 12th, 2007, 09:32 PM   #7
2003 Ford Mach
thanks for the information guys...
[SIGPIC][/SIGPIC]
Under my Umbrella!
[I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I]
Old May 12th, 2007, 11:28 PM   #8
beheivjer's Avatar
beheivjer is on a distinguished road
front and rear brackets are now discontinued from ford, i work for a motorcraft supplier so if you can find them grab them up. if anyones is interested i can get the ford pt#s monday i was going to put cobras on the front of mine but could only find a drivers bracket and i think they cost like $60 but i dont remember for sure
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Threads Similar to: Cobra brake conversion kit?
Disc Brake Conversion wonders_of_a_V8 Classic Mustangs 6 January 20th, 2009 10:16 AM
Disc Brake Conversion gotboost562 5.0 Mustangs 8 November 10th, 2007 06:38 PM
13 inch cobra brake conversion help cybertech 5.0 Mustangs 6 October 17th, 2007 01:28 PM
Brake Upgrades/ SN95 Spindles and Cobra Big Brake Kits OcOnnor220 Modular Mustangs 2 July 8th, 2007 01:36 AM
6 brake light conversion 99mustang232 Visual 0 November 27th, 2005 03:46 AM
