Can a water pump lock up?
Old May 12th, 2007, 01:45 AM   #1
monkey187 is on a distinguished road
i was driving my car today and my water pump locked up and melted my serpentine belt. My gatorback had no chance, baught a cheap one and it was working fine then my water pump locked up again. Had to tow my car for $50 to go 3 blocks. has this happened to anyone else or what the f*ck is wrong with my car?
Old May 12th, 2007, 04:25 AM   #2
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
I have seen water pumps on other vehicles where the propeller has fallen off inside, so it could be a possibility that maybe a fin fell off and jammed it up but I've never seen it happen on a Mustang before, I would rip it out and check it out though if it is giving you problems.
2004 GT Boosted by Vortech
Old May 12th, 2007, 10:12 AM   #3
zkid01 is on a distinguished road
Yes water pumps can lock up and eat your serp. belt. If i was you i would replace the waterpump.. and sense your going to be replacing it i would just upgrade to a elec. pump and get some extra hp out of it. Sorry to hear about the bad luck.
Work Hard....Play Harder.
Old May 12th, 2007, 11:22 AM   #4
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
Go elec RPM outlet or VT engines has some good prices.
Old May 12th, 2007, 12:19 PM   #5
steve_stang2003 has a little shameless behaviour in the past
Re: Can a water pump lock up?
Was the impeller in one piece when you removed the original pump?
Check real close.
Do Ford's have plastic impellers like some other cars do? (I don't know, I'm asking)
1. Water pumps do freeze up but it is rare unless they have plastic impellers.
2. Generally, you will see some signs of it getting ready to fail. Dripping from the weep hole is common as well as rattling noises.
Sounds to me like there might be shrapnel still in the cavity and that's why the new one froze on you.
Are you sure it's not the idler pulley?
Old May 13th, 2007, 05:57 PM   #6
beheivjer's Avatar
beheivjer is on a distinguished road
the bearings can go on a water pump and do but not very often out of the 20 a week i sell maybe 2 have bearing failure, usually just a gasket but since its off you might as well change it i say.
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old May 13th, 2007, 09:17 PM   #7
I havent taken it off yet I am going to take it off this week to try to fix it. The only thing that I had changed was the serpentine belt not the pump.
Old May 14th, 2007, 08:31 AM   #8
yea thats what i thought. Deff change out that pump.. and yes ford does make cars with the plastic impellers. I hate those things! But i am not sure if our mustangs have them. My water pump has been great for 100K *knock on wood* so ill let you know when it fails.
Threads Similar to: Can a water pump lock up?
Bad Water Pump? gotboost562 5.0 Mustangs 14 October 2nd, 2007 11:55 PM
what water pump 95wip 5.0 Mustangs 2 June 25th, 2007 01:04 AM
Can a water pump lock up? monkey187 General Tech 4 June 17th, 2007 11:43 PM
Water pump ??? Fastback GT Classic Mustangs 15 February 24th, 2007 03:37 PM
Water Pump cobralini V6 Mustangs 1 August 3rd, 2006 07:48 PM
