Heres my ouch video
Old May 12th, 2007, 04:01 PM   #1
MySallyMI is on a distinguished road
Heres my ouch video
The title says it all, went racing and now ive got problems. I think im looking at a complete rebuild, havent gotten a compression tester on it yet, tuesday will be the day for that. Ive lost alot of power it knocks deeper now, its fucked. http://vids.myspace.com/index.cfm?fu...oid=2028231021 Got a couple of other videos there to look at as well as an old one. Right when i was thinking about selling it too...i swear im Al Bundy with my shitty luck.
Old May 12th, 2007, 04:23 PM   #2
zkid01 is on a distinguished road
Damn man that sucks ass!
Work Hard....Play Harder.
Old May 12th, 2007, 05:32 PM   #3
1999 Mustang
Invictus is on a distinguished road
can't really tell what the problem is... need better quality sounding video. is it just a bad tick noise? if it still seems to be running okay than it may not be that major.. might just need a valve job or something
Old May 12th, 2007, 05:49 PM   #4
FOR POINT SIX's Avatar
FOR POINT SIX is on a distinguished road
How long has it been smoking, in your other video there a lot of it.
http://vids.myspace.com/index.cfm?fu...oid=2028233057
Old May 12th, 2007, 06:30 PM   #5
OcOnnor220 can only hope to improve
My brother you might wanna check the level cause that almost looks and sounds exactly what happened to my 1996 GT when I accidentally put 12qts. of oil in instead of 6 (the maximum)...Even if THAT isnt the problem, that smoke is a dead giveaway...its not burning the oil correctly. My advice is check the oil pan for leaks (take it out) and possibly the engine intake and valve cover gaskets. Im no mechanic though, but that video looks EXACTLY like an overfilled or leaking oil problem.
Old May 12th, 2007, 07:21 PM   #6
If you look the burning is not coming from something leaking, its coming from the tail pipes. This is something internal. The good thing is now you have an excuse to go forged.
Old May 12th, 2007, 07:27 PM   #7
M.O.B.Fab's Avatar
M.O.B.Fab is on a distinguished road
Send a message via AIM to M.O.B.Fab
i bet you fried a piston...
M.O.B. Fabrication
Huntsville/Cullman, AL
256-297-6015
Old May 12th, 2007, 07:32 PM   #8
What happened originally is it burned up most of the oil while drag racing. I added 3 quarts that night drove it home, the next day it didnt knock anymore. Ive taken it apart checked the cam replaced a couple out of spec lifters and one rocker, put it back together, changed the oil from 5w-30 full synthetic to 10w30 conventional and it smoked like on the video. A couple days later it stopped smoking as much and started knocking, but the oil level is fine. So the knock is now here to stay. Like i said Tuesday ill hook up a compression tester and then ill be sure of what happened.
Old May 12th, 2007, 08:04 PM   #9
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
sometimes when you run low on oil you can actually make your cam chain tensioner go bad which actually uses oil pressure to keep the tension and the knocking could be the chains hitting the tension arm
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old May 12th, 2007, 08:13 PM   #10
MachIt's Avatar
MachIt is on a distinguished road
Send a message via AIM to MachIt
yea, thats what happened to my ex's 96gt...
04 DSG Mach 1
-AmericanRacing Anthracite TorqThrusts:
18x9 fronts on 255/35/18 NT555s
18x10 rears on 285/35/18 NT555s
-NGK TR55 IX plugs
-Steeda Triax
Old May 13th, 2007, 05:43 AM   #11
Drgnracin72's Avatar
mine used to sound like that, and then it exploded!!! have fun and start saving for a new motor
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old May 13th, 2007, 08:15 AM   #12
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
man that souds sick. sorry bout your luck man.
Threads Similar to: Heres my ouch video
Heres you sign 97Cobra The Clubhouse 20 March 20th, 2008 12:34 PM
Heres my new stance! JAY'SRED02 2005 - 2010 18 September 3rd, 2007 11:10 PM
Ouch... speedo incorrect! BlueOval 5.0 Mustangs 2 August 3rd, 2007 06:37 PM
OUCH!!! 06RedfireGT The Clubhouse 18 July 22nd, 2007 02:33 PM
Ouch!! Stangzilla Videos 10 February 8th, 2007 01:26 PM
