Replacing 4.6 Rod bearings while in car. - Forums at Modded Mustangs
post #1 of 19 Old June 21st, 2011, 05:07 PM Thread Starter
Searched around and found a bit of info but mostly just people saying to pull the motor and get a new one built at a shop. I thought I saw an article on here awhile ago on how to do this but was unable to find it.
Basically my car has a rod knock between 2000-3000rpm's while under a load only, I got a full set of rod bearings and want to replace them while the engine is still in the car. Do I have to pull the crank? Does the K-Member have to come out to remove the oil pan or can it all be done with the k member in place?
danielholmesGT is offline
post #2 of 19 Old June 21st, 2011, 05:11 PM
Mineral_Grey_Gt's Avatar
Pull the motor out, it will be 65,000 times easier to on.
Mineral_Grey_Gt is offline
post #3 of 19 Old June 21st, 2011, 05:20 PM
Head Unicorn
bulloch27's Avatar
If you use an engine cradle you could drop the k member and have full access to the pan for removal. I wouldn't attempt that though. It would be infinitely easier to pull the motor, even if you only replace the bearings. You're talking about having to wrestle with a heavy ass crank laying on your back and trying to get the rods back on the journals blahblahblahblah. It just seems like a disaster waiting to happen to me.
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX
Unicorn Club Founding Member
bulloch27 is offline
post #4 of 19 Old June 21st, 2011, 05:25 PM Thread Starter
Well it would be two of us working on it and I wanted to see if it's possible to pull the pan and not drop the k member. Also we were tossing the possibility of not dropping the crnk just spinning them in one cap at a time.
post #5 of 19 Old June 21st, 2011, 05:43 PM
Head Unicorn
bulloch27's Avatar
Perhaps if the motor was jacked up high enough but I promise you the K member is easy as hell to pull. Two nuts and one bolt at the top of each strut tower, eight bolts on the K and it's gone. Takes me twenty minutes to drop a K. It's too quick and easy to get out of the way and will give you a shit load of room. If you're gonna do what you're saying that will be the easiest way.
post #6 of 19 Old June 21st, 2011, 05:52 PM
Head Unicorn
bulloch27's Avatar
I did leave out the two motor mounts, removing the front tires and brake calipers but I'm serious about the twenty minute removal time.
post #7 of 19 Old June 21st, 2011, 07:17 PM
86er's Avatar
the crank doesnt have to come out to replace the rod bearings, BUT you dont know what kind of damage is done to the journal on the crank and if its chewed up at all youll be right back to square one replacing bearings again
Just a truck
86er is offline
post #8 of 19 Old June 21st, 2011, 09:01 PM
If your bearing went out that means you could have metal shavings all over the place. I would be scared to just put new bearings in. I would want to have all of the oil gallies cleaned out.
Airmandavis is offline
post #9 of 19 Old June 21st, 2011, 09:12 PM
Procrastinator
You could change them but chewed up bearings get spit out somewhere else. You need to tear it all apart and clean it up to make sure you are just dealing with changing bearings.
DickH is offline
post #10 of 19 Old June 21st, 2011, 10:14 PM
y2k02's Avatar
I have replaced rod bearings with engine in car. I have a tubular k-member and did not have to drop it. It was for sure easier than pulling the engine.
2002 GT~Forged Teksid~ Trick Flow
Big Cams~RR Intake ~160lbers ~E85
Twin 61mm Turbos TH400 & UCC converter
Home built Holley Dominator tuned by me
2016 Mustang GT keeping it stock
y2k02 is offline
post #11 of 19 Old June 22nd, 2011, 09:43 AM
Head Unicorn
bulloch27's Avatar
I have done this in the past, just never to one of my mustangs. I've replaced bearings, parked outside on the lot with the newly non-knocking motor and for sale sign on the dash. I wouldn't do it that way on what I was gonna keep. just saying.
post #12 of 19 Old June 22nd, 2011, 08:27 PM
tjpinkston's Avatar
If u have a stock K then itll have to be dropped, and you can just rotate the crank and do the bearings in pairs. Crank can be polised with emery cloth or get some 1000 grit and tear into strips. Depd on the severity of the failure some pieces of the bearing may be stuck to the crank. Make sure to clean everything well and lube the hell outta the new bearings
04-160 s281sc convertible
68 f100 turbonetics 4.6
tjpinkston is offline
post #13 of 19 Old June 22nd, 2011, 08:42 PM
Hooo Ha Ha
sharkbait's Avatar
iTrader: 10 reviews
Its really easy to pull these motors. i dont know why your so afraid to pull it.
853rwhp @ 23psi
75mm Turbo 5.4 swap E85
#turbo2v
10.11 @ 138mph STOCK LONGBLOCK
9.11 @ 149mph - New Longblock /w Powerglide
www.JPCracing.com 410-729-0005 ext. 11
PM me if you need any parts or advice!
sharkbait is offline
post #14 of 19 Old June 23rd, 2011, 01:58 AM Thread Starter
I'm not afraid to pull it, it's just easier done this way. Project was done in a little over 6 hours starts to finish. We dropped the crank, cleaned everything really good, put it back together with new bearings well lubed up, new oil and fired it up. No more knock but we did put a magnet on the pan to draw all the shavings down. I am in agreement with you though, if I was keeping the car I would not have done it this way but as the car is sold (Traded rather) I'm not too worried about it. Dick move I know right?
post #15 of 19 Old June 23rd, 2011, 02:10 AM
Head Unicorn
bulloch27's Avatar
LOL, yes definitely a dick move. You adequately repaired the problem. I've done the same..... as-is no warranty have a nice day.
post #16 of 19 Old February 5th, 2012, 02:11 PM
cschoening09's Avatar
iTrader: 10 reviews
Magnet on the pan? I thought rod and main bearings were aluminum?
2014 A6 GT Sterling Gray. SR performance lowering springs, J&M adj. panhard and Stainless power longtubes - o/r x awaiting tuner and install.
cschoening09 is offline
post #17 of 19 Old February 13th, 2012, 08:22 PM
Better than Drugs!
mayosailor27's Avatar
oh man i am about to try this out....knocking on my car. we wil see
96 GT-sold
98 GT-parted
90 GT-traded
98 GT-traded
98 GT-parted
94 GT/Cobra-sold
95 Cobra Saleened-sold
97 Cobra-sold
99 GT-sold
97 Cobra-sold
95 Cobra- sold
97 Cobra-parts
96 Cobra-sold
96 Cobra- Project "Dead Pony"
MM Cobra member 969
mayosailor27 is offline
post #18 of 19 Old February 13th, 2012, 09:30 PM
Keep oil in them, they wont knock lol
1999 GT 630rwhp on pump, TFS Heads, MMR 4.75L, Highly Modified Kenne Bell 2.1 @ 20lbs, Custom Intercooler, JLT High Boost CAI, CMS Custom TFS Specific Cams, 3.55s, MGW, T56
Nitmare67 is offline
post #19 of 19 Old February 13th, 2012, 10:23 PM
BakerFX4's Avatar
iTrader: 15 reviews
Ok... Ill give my recent experience on this.... I had "rod knock" (spun rod bearing) in my motor here recently. I pulled K member, replaced bearings and put it back together. As EVERYONE said, it did not last. Might have lasted 600-800 miles. Ive got it pulled apart now and its the same rod and the bearing is wore out again! Dont waste your time dude. You cant get away with doing that shit. If you decide to, good luck! You'll need it!
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
Human Verification
