4.10 in my car
Old May 13th, 2007, 10:59 AM   #1
mrnewall is on a distinguished road
4.10 in my car
iv decided after reading the posts to get 4.10s i just think it will be better in my auto gt then other gear ratios. On Americanmuscle they have kits which come with a wee computer thing to adjust your mph gauge. Could a mechanic just install the gears and sort out the speedo themselves or would i be better off getting a kit? i was looking at the
Speed Cal and 4.10 Gears Kit what do you think?? Also with a good mechanic how much labour is normally required?
cheers steve
Old May 13th, 2007, 11:00 AM   #2
HMUSN's Avatar
iTrader: 9 reviews
Your going to need either the speedcal or a tuner to fix your speedo man.
no way around it.
Labor is about 2-3 hours.
Old May 13th, 2007, 11:15 AM   #3
HMUSN's Avatar
iTrader: 9 reviews
And the DR you plan on getting will have no affect on the install of the gears.
Old May 13th, 2007, 11:15 AM   #4
will the Mustang Speedcal which comes with the gear kit make my speedo accurate then?? What about if im changing the tires at the same time as the gears? Will this affect the speedo even with the electric calibrating thing?
Old May 13th, 2007, 11:19 AM   #5
HMUSN's Avatar
iTrader: 9 reviews
Yes it will fix your speedo. that's the job of the speedcal
your tires won't make a difference unless you change the size of them dramatically
Old May 13th, 2007, 11:44 AM   #6
amazing thanks v much man , do you think a ford garage would do the install well? The really only other place is a ricer tuning shop so i dunno if i would trust them!!
Old May 13th, 2007, 11:48 AM   #7
HMUSN's Avatar
iTrader: 9 reviews
you mean the dealership?
Yes the do a good job most of the time but it will cost you.
look for a good speedshop around the area before you go to Ford.
Old May 13th, 2007, 12:00 PM   #8
HMUSN's Avatar
iTrader: 9 reviews
here you go man.
http://cgi.ebay.com/ebaymotors/96-04...spagenameZWDVW
