Looking for a 6-8 lb. blower?
Old May 13th, 2007, 11:24 AM   #1
bossman2kgt's Avatar
bossman2kgt is on a distinguished road
Newbee here. Got a question. I have been outside the aftermarket scene for a while and is now wanting to get a blower for my 2000 gt. Budget wise I don't want to spend more that $2200 and between 6-8 lb. boost since my stang is mostly stock besides the free flow exhaust headers on back and upgraded throttle body. If anyones some tips I'd really appreciate it.
Will
Old May 13th, 2007, 02:43 PM   #2
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Most blowers you can switch the pulley to get around whatever you want... And for that much you would need to find a used kit.
Old May 13th, 2007, 03:22 PM   #3
zkid01 is on a distinguished road
You would have to find a used kit for that low... of a budget and there is no garentee its going to come with everything youll need. You better off saving and 2K.
And as far as the boost you can switch the pulles to generate the amount of boost you want. there is also programing you can do to adjust boost.
Good Luck with your build.
And Welcome to the site... there are allot of good guys on here and they can help with allot of the qs you have.
Work Hard....Play Harder.
Old September 8th, 2008, 08:09 PM   #4
ms85stang's Avatar
1985 mustang gt
12.98@104.6
ms85stang is on a distinguished road
Send a message via AIM to ms85stang
why go with a blower with the minute amount of mods you have. put a cam and some heads on. work the ignition some pulleys and gears and you will get as much hp as a blower would have given you
Old September 8th, 2008, 09:51 PM   #5
supercharged03gt's Avatar
2003, Mustang, GT
supercharged03gt is on a distinguished road
you can find one on ebay for around that price, but you are going to have to get it dynoed witch is around $300 depending on where you go and if you dont install it yourself the install will go for about $500. Also you can go more than 6 to 8 psi. at least go with 10
Mods: Vortech V-1 supercharger, BBK LT headers, BBK o/r X pipe, Flomaster cat back, 4:10 gears, Centerforce clutch, Fidneza aluminum flywheel, K-member, Eibach pro kit, MM caster camber plates, Eagle F1 tires 275 & 315.
Threads Similar to: Looking for a 6-8 lb. blower?
which blower FastBack71 5.0 Mustangs 25 September 8th, 2008 08:37 PM
N/A Cam and Blower Cam ??? StuTheMusicEngineer 99-04 1 March 3rd, 2007 04:35 AM
Blower justinsstang General Tech 11 March 1st, 2007 10:19 PM
which blower 342stroker General Tech 2 February 14th, 2007 06:20 AM
Blower is on car! cooktheworld 5.0 Mustangs 3 December 19th, 2006 01:26 PM
