upgraded REAR END suggestions?
Old May 13th, 2007, 04:24 PM   #1
1999 Mustang
Invictus is on a distinguished road
Alright... I'm about to be nearly 500RWHP at the wheels with my new setup and obviously I want to beef up the rear end...
If you guys were in my shoes what exactly would you buy to be completely safe...
I've been recommended the Richmond Powertrax 8.8 rear and the EV84 Superior axle 31 spline kit... I was told that would replace all the friction disks in my factory differential and i'll also be putting some 3.73's in.
This is what one guy recommended to me, I was wondering what all you guys would do if you were in my shoes...
Thanks
Old May 13th, 2007, 04:36 PM   #2
zkid01 is on a distinguished road
If i was to build up my rear end i would be upgrading to a positrack, upgraded 31 spline axels, gears. I havent really seen anyone gernade our stock housings so i dont think you would have to worry about that. Hopefully someone a little closer to your powerrange will post up for ya. But that is my opinion.
Work Hard....Play Harder.
Old May 13th, 2007, 05:26 PM   #3
2001 cobra
01whitecobra is on a distinguished road
Send a message via AIM to 01whitecobra
Moser 31 Spline Axles, ARP 3in wheel studs, Detroit True Trac Locker Diff, FRPP 4:30 gears, FRPP diff. cover, welded axle tubes, UPR upper and lower control arms, UPR spherical bushings, and a MMR coilover setup.
my setup will hold allot of power, and i mean allot.
Old May 13th, 2007, 07:22 PM   #4
Proud American
MustangMatt96GT's Avatar
Welded Axle tubes are a must! And I would go with 31 spline axles which would also mean you would need a 31 spline t-loc!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old May 13th, 2007, 08:21 PM   #5
ujslost's Avatar
sounds like a great recipe to me for a strong rear end. especially the 3 inch wheel studs and the 31 splind moser or strange axles
Old May 13th, 2007, 09:02 PM   #6
2001 cobra
im partial to moser. i dont really trust superior.
Old May 13th, 2007, 11:14 PM   #7
ujslost's Avatar
same here
Old May 14th, 2007, 01:45 AM   #8
1999 Mustang
That sounds like a lot of cash..! I'm trying to keep it to a minimum. As of now I have FRPP 3.73's (still in BOX) waiting to be installed and then the factory stock GT rear end... I know all of those suggestions would make for a beast rear but i'm sure that's a bit overkill not to mention expensive. Realistically, what exactly what I need to handle 5-600HP (incase i upgrade to the whipple or KB in the future). Trying to save as much as possible, still need intercooler, pumps, resoviors, waterpump, interooler, and full length subframe connectors.
Thanks!
Old May 14th, 2007, 08:45 AM   #9
Well if your boosting your car you should already know that cheap isnt the way to go. Mine was probably the simple description but i forgot about the welded tubes.. those will be needed. 01WhiteCobra gave to you best description for a bullit proof rear end. Do it once do it right.
Old May 14th, 2007, 11:23 AM   #10
MachIt's Avatar
MachIt is on a distinguished road
Send a message via AIM to MachIt
if you're lookin for cheap, just do 31spline shafts and a new traclock...then go from there with studs, have the tubes welded....but i'd probly get the shafts and tlock first...
04 DSG Mach 1
-AmericanRacing Anthracite TorqThrusts:
18x9 fronts on 255/35/18 NT555s
18x10 rears on 285/35/18 NT555s
-NGK TR55 IX plugs
-Steeda Triax
Old May 14th, 2007, 11:45 AM   #11
superbeef1000's Avatar
Moser 31 Spline Axles, 31 spline track lock , use your 3.73 gears , maxum motorsports uper and lower control arms that should be a good start
Threads Similar to: upgraded REAR END suggestions?
My Visually Upgraded 94 GT [ DUW ] Kingcater 94-95 2 November 12th, 2007 02:58 AM
Rear diff for sale... need suggestions msolaas1 2005 - 2010 2 July 18th, 2007 02:54 AM
Any suggestions for V6 stagecrewgod V6 Mustangs 58 April 17th, 2007 02:42 AM
Upgraded Driveshaft for 07 2wd F150 Ext. Cab DaveT All Other Vehicles 0 March 5th, 2007 04:40 PM
upgraded rods kbstang 99-04 4 March 22nd, 2006 11:27 AM
