Why is my coolant so dark? - Forums at Modded Mustangs
post #1 of 6 Old June 28th, 2011, 08:58 PM Thread Starter
I Have A FLATULENT Butthole.
(Kohrs93)'s Avatar
Well 2 weeks ago i had my intake crack. I replaced it with the 01-04 manifold with the aluminum crossover. Ever since I got it all back together, I've noticed that my coolant is a really dark green. And it seems like when its hot there is more in the coolant resevoir than when it's cold. Did I put too much coolant in? How dark is it supposed to be?
Black Stang Crew #Coorslight
BONER CREW EMPLOYEE #3 - RECEIVING DEPARTMENT
[CUMYUM!]
i like pee pees i guess too
(Kohrs93) is offline
post #2 of 6 Old June 28th, 2011, 09:04 PM
Send a message via Skype™ to BlueGT01
Well its not supposed to be dark at all i would assume. Bright green is what it should be.
Vortech'd 663rwhp 621 ft lbs
BlueGT01 is offline
post #3 of 6 Old June 28th, 2011, 09:06 PM Thread Starter
(Kohrs93)'s Avatar
That's what i was thought... Is there anyway to completely drain my whole coolant system?
[CUMYUM!]
post #4 of 6 Old June 28th, 2011, 09:17 PM
How To Flush Your Mustang Coolant
There ya go.
BlueGT01 is offline
post #5 of 6 Old June 28th, 2011, 09:19 PM
Head Unicorn
bulloch27's Avatar
Petcock vavle on the bottom of the radiator, or the easier, faster way: pull the lower hose. You'll never completely drain the engine of the coolant that's in it.
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX
Unicorn Club Founding Member
bulloch27 is offline
post #6 of 6 Old June 28th, 2011, 09:21 PM
Drain that valve, put a hose in your resivoir with a slow flow. start the car and run it until the water coming out of the valve is clear. then turn the car off, close the valve once it finishes draining. Then fill as needed.
BlueGT01 is offline
Human Verification
