Discussing Oil leak problem in the 99-04 Forum. Hey everyone well I have a small oil leak that is dripping down the driver ...
Old May 14th, 2007, 11:58 PM   #1
Oil leak problem
Hey everyone well I have a small oil leak that is dripping down the driver side H pipe. It is comming from somewhere up top and going down the exhaust pipe and dripping where the pipe bends to go towards the back. I cant see where it is comming from. I took it to where I got my engine installed and they replaced the valve cover gasket but now I got home and it is still leaking. Anyone have any ideas of where it could be comming from??
Old May 15th, 2007, 02:05 AM   #2
Garhfer's Avatar
2004 Mustang GT Conv.
What kind of gasket did they use? If Felpro I'd try to tighten down the bolts on the valve cover.... I guess you could also check the pvc valve hoses sometimes their is oil in those uhmm... I can't think of anything else.
2004 GT Boosted by Vortech
Old May 15th, 2007, 02:06 AM   #3
I dont know what type of gasket. Where is the PVC hose at?
Old May 15th, 2007, 02:09 AM   #4
Garhfer's Avatar
They're the hoses that come out the top of the valve covers. uhmm... lemme see if I can find a pic
Old May 15th, 2007, 02:30 AM   #5
Garhfer's Avatar
This is the pvc valve with an oil separator on it, so it's not gonna look the same but it'll give you an idea of what it looks like... it's toward the rear of the engine on top of the valve cover with a hose coming out of it.
Old May 15th, 2007, 08:12 AM   #6
Did you clean up all the oil that was already leaking after you replaced the gasket?
Work Hard....Play Harder.
http://i142.photobucket.com/albums/r...dMustangs2.jpg
Old May 15th, 2007, 01:01 PM   #7
Yeah I cleaned it up the best I could. I know its not the PVC valve. It is somewhere further down where I cant see.
Old May 15th, 2007, 02:41 PM   #8
hmm...im trying to think if there is anything else up that high that would cause you to be loosing oil... Besides the valve covers...are you sure its oil and not some other type of fluid? Im not saying you wouldnt know what oil is.. im just makeing sure we are following the right path.
Old May 15th, 2007, 11:09 PM   #9
Yeah I am pretty sure. It is like a like kind of dark brown black like its clean oil but then again the oil has only been in there since the week after Easter.
Old May 16th, 2007, 03:18 AM   #10
bump!
Threads Similar to: Oil leak problem
leak??!!! mustang fanatic 2005+ 15 June 10th, 2008 05:50 PM
Leak garydahl Modular Mustangs 6 August 7th, 2007 03:06 PM
Evaporative Emission System Leak Detected (very small leak) Juggalo_X V6 Mustangs 11 April 25th, 2007 04:46 PM
Oil Leak Stangzilla 5.0 Mustangs 25 November 6th, 2006 05:00 PM
What is this leak ??? toddman0025 Classic Mustangs 4 August 13th, 2006 01:28 AM
