OME throttle bodys?
Old May 15th, 2007, 07:04 AM   #1
mrnewall is on a distinguished road
OME throttle bodys?
has anyone herd of or got a OME throttle body? How do they compaire to others like bbk. Iv seen a few on ebay and one guy on this site is selling them quite cheap
thanks steve
Old May 15th, 2007, 07:17 AM   #2
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
maybe he means OEM? which is the factory throttle body.
2004 GT Boosted by Vortech
Old May 15th, 2007, 07:48 AM   #3
yeh shit thats what i ment!! So these throttle bodys are just the standard which comes with out car? Not preformance ones
Old May 15th, 2007, 07:52 AM   #4
Garhfer's Avatar
yeah, OEM means Original Equipment Manufacturer
Old May 15th, 2007, 08:50 AM   #5
zkid01 is on a distinguished road
Yep OEM is what comes with the vehicle from the factory. Accufab is a great company for throttle bodys and plenums. You will notice some diffrence but, it will benifit more once you are boosted.
Work Hard....Play Harder.
Old May 15th, 2007, 08:53 AM   #6
cheers. I think my throttle body could be abit clogged up as the idle can be dodgy, whats the best way to go about cleaning it? Do you clean the plenium at the same time?
Old May 15th, 2007, 09:01 AM   #7
ok heres what you do.. go the the autoparts store and pick up a can of throttle body cleaner and a copper (the gold color) wire brush.. Take off your air intake and open your throttle body... Spray a little bit of cleaner around the insides of the throttle body and spray the plate a little bit. youll see some drain back out thats ok.
Take the wire brush and LIGHTLY brush off the junk around the inside and lightly brush off the top and bottom of the plate.. Spray it out again to clean it out. And put your intake back on.. You can also spray the spring on the side of your plenum that is connected to the throttle body plate.. Sometimes gunk gets builded up there too. This should take care of it for ya!
Oh and BTW when you first start your car after doing this it may sputter for a second... its ok its just buring up the cleaner that made it down the intake and into the cylinder. It may throw a little bit of smoke too.. This will go away after a quick drive. Or engine rev.
Let us know if there is anything else.
Old May 15th, 2007, 10:58 AM   #8
thanks v much ill let you know how i get on
Threads Similar to: OME throttle bodys?
new throttle body poof505 V6 Mustangs 15 November 4th, 2007 08:54 PM
Throttle Lag superpede1 V6 Mustangs 21 August 30th, 2007 04:31 AM
Throttle Body Sh0gun! V6 Mustangs 16 April 23rd, 2007 09:25 PM
throttle u-wish 5.0 Mustangs 3 April 8th, 2007 10:04 AM
