if a camshaft position sensor is bad.... - Forums at Modded Mustangs
post #1 of 23 Old July 26th, 2011, 11:51 PM Thread Starter
BakerFX4's Avatar
iTrader: 15 reviews
how will it act?
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
post #2 of 23 Old July 26th, 2011, 11:59 PM
PRODUCTIONMAN's Avatar
engine will miss and run rough and act the same as a bad coil or plug (or worse). Just had it go out on my Denali dd.
PRODUCTIONMAN is offline
post #3 of 23 Old July 27th, 2011, 12:01 AM
Head Unicorn
bulloch27's Avatar
That's a question I'd like to know the answer to also. I've never had one/worked on one that had an issue with the CPS. What are the symptoms???
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX
Unicorn Club Founding Member
bulloch27 is offline
post #4 of 23 Old July 27th, 2011, 12:09 AM Thread Starter
BakerFX4's Avatar
iTrader: 15 reviews
well my harley truck has been acting STUPID and its real random... just starts bucking its ass off and then its completely fine again. Im like WTF? I can throw it in park and rev it way up and all and no issues and then it just randomly starts bucking bad and even knocking sound.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
BakerFX4 is offline
post #5 of 23 Old July 27th, 2011, 12:09 AM
mrbigjeep's Avatar
my buddy has a v6 mustang and had either a bad cam syncro or sensor and it was bad enough to where the engine would lock up and stall the car at idle...it would buck and then want to lock up and cut off.
mrbigjeep is offline
post #6 of 23 Old July 27th, 2011, 12:09 AM
mell0's Avatar
Send a message via AIM to mell0
I've heard most "cam position sensor" problems were in fact alternators going out. Even if at first the alternator checks out at autozone or something, try swapping it with another to see if the problem is fixed.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
mell0 is offline
post #7 of 23 Old July 27th, 2011, 12:12 AM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
Baker hows your stang running? Did you drop the oil pan or anything?
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is online now
post #8 of 23 Old July 27th, 2011, 12:36 AM
mell0's Avatar
shaun sick sig BTW
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
mell0 is offline
post #9 of 23 Old July 27th, 2011, 12:41 AM
iTrader: 27 reviews
Thanks man
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #10 of 23 Old July 27th, 2011, 01:00 AM
Mechanical Engineer
nathanielwilliam's Avatar
had a problem with mine once where i thought the sensor was bad. ended up being that the guy before me ran the wiring harness over the egr valve line and it melted the wiring harness and was shorting out the wiring. sensors rarely go out.
2006 Mustang GT
Pacesetter Ceramic L/T's
Pacesetter H-pipe
FR hot rod cams
FR Intake manifold
FR500 exaust
Hurst Competition Plus Short throw.
JLT CAI
2002 F-150
Sold:
2001 Mustang GT (miss this one)
nathanielwilliam is offline
post #11 of 23 Old July 27th, 2011, 08:38 AM
When that happened to me it was my broken diodes in my alternator. After wasting $55 to replace the sensor, I just had the alternator rebuilt and it solved the problem just fine. They explained it that when the diodes break, they send out a pulse signal that fucks with that sensor and makes it say it's broken because it doesn't function as it should
TRUE BLUE CREW MEMBER #6
02'TrueBlue is offline
post #12 of 23 Old July 27th, 2011, 10:32 AM
Applehead281's Avatar
Had the exact same problem with mine i went through 3 alt's from carquest and the diodes failed in all three, took it to a elec shop and i got a USA made one from him brand new for like 10 more bucks than a refurbished one from mexico costed me at carquest, and he told me that it creates a magnetic field causing the cam sensor to fail, it did it would start and die and sometimes backfire realllllly bad it sounded like a cannon!!!!
The usual bolt on's..
Applehead281 is offline
post #13 of 23 Old July 27th, 2011, 03:57 PM Thread Starter
BakerFX4's Avatar
iTrader: 15 reviews
this is why i asked.....
I got some codes that popped up. One was an alternator code and the camshaft position sensor code. I will add... my truck has been sounding weak when it starts for about 3-4 months lately. Crazy that an alternator can make the motor buck arround and even die!
As far as my stang... Now Im wondering if the car isnt doing the same thing! Cause it did the same shit and made some horrible knocking sound. I noticed it one day at a restaurant... drove it home and it quit. Then the last time i drove it, it ran fine, pulled crazy hard through the RPM range and on my way back home it started that knocking shit and then for the rest of the evening it sounded like that and even killed the car one time. As if it locked up! But then it started back up and all. So could both my rides be suffering from the same shit? Do alternators really fuck shit up that bad!?
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
BakerFX4 is offline
post #14 of 23 Old July 27th, 2011, 04:49 PM
It sure did for me mine started doing it in the winter, it would start backfire and die and again then it would start, sometimes the battery light wouldn't come on until the motor got warm and the diodes seperated, therefore causing a magnetic field around the cam pos sensor causing it not to know where the actual cam is even located. When i got the new one on it was right back to its old self and haven't had a problem for two years now, ps don't get one from carquest!!!!!!!!!!!!
post #15 of 23 Old July 24th, 2013, 08:03 PM
5oh1990's Avatar
just wanted to say great thread. Im having some (what i believe are) cam/crank position sensor codes, but i also know for a fact that my alt is bad. maybe ill replace the alt before i decide to replace the sensors. thanks again
I'm new to MODs so plz excuse the stupidity.
5oh1990 is offline
post #16 of 23 Old July 24th, 2013, 08:05 PM
Froush's Avatar
iTrader: 8 reviews
Welcome. You realize this thread is 2 years old?
"Happiness is being blown and stroked at the same time"
V6 => Teksid 302 stroker 644hp/576tq.
Caitlyn Jenner build underway
My Build Thread click link
http://www.moddedmustangs.com/forums...shs-build.html
Froush is offline
post #17 of 23 Old July 24th, 2013, 08:06 PM
KCCO
codycat91's Avatar
iTrader: 14 reviews
shit happens
Sent from AutoGuide.com App
Centennial GT Project
My weakness becomes my weapon, and pain my pleasure
Originally Posted by GCubersoldat View Post
I'll buy a Chevy before i go back to MMR.
codycat91 is offline
post #18 of 23 Old July 24th, 2013, 09:14 PM
FakeSnake's Avatar
is'nt the first and it definately won't be the last , good info though.
FakeSnake is offline
post #19 of 23 Old July 24th, 2013, 09:18 PM
Froush's Avatar
iTrader: 8 reviews
I agree. I wasnt really getting on him. Just pointing it out
Froush is offline
post #20 of 23 Old July 24th, 2013, 11:44 PM
I Have A FLATULENT Butthole.
(Kohrs93)'s Avatar
Person A: makes new thread about a problem
Person B: USE THE SEARCH BUTTON!!!!!!!!!!!!!!!!!@!!!!!!!!!!!
Person A: Uses the search button and bumps 2 year old thread
Person B: WAY TO BUMP AN OLD THREAD YOU ******* UGLY PIECE OF **** WHAT IS WRONG WITH YOU LEAVE OUR FORUM NOW!!!!!!!!!!!!!
Welcome to MM
Just given ya shit Froush!
Black Stang Crew #Coorslight
BONER CREW EMPLOYEE #3 - RECEIVING DEPARTMENT
[CUMYUM!]
i like pee pees i guess too
(Kohrs93) is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/227434-if-camshaft-position-sensor-bad.html
Thread Camshaft sensor location?? | Forums at Modded Mustangs | BoardReader This thread Refback November 13th, 2011 10:36 AM
