6061 Elbow Installed!
LinkBack (1) Thread Tools
Old July 30th, 2011, 02:29 PM   1 links from elsewhere to this Post. Click to view. #1
2001 Mustang GT
blkgtstang is on a distinguished road
Hey guys just got the 6061 elbow installed on the Edelbrock manifold and thought id share it with everyone.. If anyone has any questions about the install or performance gains let me know i can help ya out with whatever you need. Oh and 1 Question to anyone who has this on there car already... I installed it .. everything is running fine idling fine drives fine... but at idle i hear a very high pitch whistle. i cant tell if it is there while im driving due to the fact that the exhaust drowns out everything lol but at idle there is definitely a high pitch whistle. is it possible that the manifold is pulling in so much air that the air flowing past the throttle plate at idel is causing a whistle??? or could this be a normal intake whistle???
01 Black GT Manual. K&n Intake, Jegs O/R H pipe, Magnaflow cat back, SCT Bama Custom Tune, 4.10 gears, Edelbrock Intake manifold, 6061 Elbow, EGR delete. MGW Short Throw Shifter
Old July 30th, 2011, 03:12 PM   #2
13.91 @ 102.04
02'TrueBlue will become famous soon enough
How does it feel?
TRUE BLUE CREW MEMBER #6
Old July 30th, 2011, 05:25 PM   #3
xXJayManZXx17's Avatar
xXJayManZXx17 will become famous soon enoughxXJayManZXx17 will become famous soon enough
nice man that looks sick
Flowmaster/UPR/BBK/SCT Tuned by DEZ Racing
Novi2000 350RWHP/333RWTQ through an auto
Supercharged Club Member #4
sold
Originally Posted by thrasher View Post
men are simple ... it goes eyes belly cock .. get them a toy feed them some food then put it in your mouth ...
Old July 30th, 2011, 05:47 PM   #4
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Looks badass. I love that setup.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old July 30th, 2011, 06:30 PM   #5
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
It looks like your running the stock tb still. Also the whistle is common since the material is real thin. Are you still na or do you have nitrous
bone stock from the factory!
Old July 30th, 2011, 08:35 PM   #6
MikeJones's Avatar
13.7@103
MikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really nice
How hard was it to get those fuel rails to hook up to your stock fuel plumbing? Also, Whats your hood clearence like on the stock hood?
What kit did you go with for your EGR delete?
Mod6
Bigbore
Kooks
(parting out 2v motor)
Old July 30th, 2011, 08:48 PM   #7
2001 Mustang GT
Originally Posted by 02'TrueBlue View Post
How does it feel?
Feels Great Excellent Throttle response and everything just feels smoother. would definitely recommend it to anyone.. Great product!
Old July 30th, 2011, 08:50 PM   #8
2001 Mustang GT
Yes it is the stock TB as of right now i have a 75mm Accufab on the way as we speak should be on next weekend hopefully! Still N/A getting ready to buy/install the on3 turbo kit... that will b another thread so you can see how that goes
Old July 30th, 2011, 08:59 PM   #9
2001 Mustang GT
The fuel rails were not to hard but the fittings are expensive!!! there are a million and 1 ways to route the fuel lines i just liked this set up personally.. but the main components you need for the fuel rails ( or at least what my set up needed) are a fuel adapter block with a ford fuel line female end and a aeroquip ford FPS adapter block. as far as the lines and T or elbows you need are all up to how you want it.( pics of the special items below) as far as hood clearance i had no problems with clearance. the throttle linkage hit the hood liner when the throttle was depressed but after a drive it dug it self a spot so that it did not hit anymore lol. and as for the EGR delete. There is a SUPER easy was to delete it without having to cap off or cut any vacuum lines. all you need is a 5/8 flare cap to cap the EGR port on the header. and you can disassemble all the vacuum lines and reconfigure them yourself so that you only have the vacuum line coming from the passenger side firewall to the throttle body(i replaced the stock red line with the green EGR line that you obviously don't need any more) and from the throttle body to the FPS. If you want more detailed EGR delete just PM me and i can walk you through it
Old July 30th, 2011, 09:00 PM   #10
2001 Mustang GT
And just so everyone knows i fixed the whistle... was coming from the stock throttle body gasket... got a new one and whistle went away!
Old July 30th, 2011, 11:23 PM   #11
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
good ole vacuum leak.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old July 31st, 2011, 09:34 PM   #12
MikeJones's Avatar
13.7@103
Just pulled the trigger and bought the manifold jegs and summit are cheaper than AM.
Going to order this Edelbrock Ultra Low Profile Mustang Throttle Body Intake Elbow at AmericanMuscle - Free Shipping!
With Zex Nitrous Oxide Systems 82043 - ZEX Perimeter Plates - Overview - SummitRacing.com
So it'll hopefully fit under the stock hood.
Mod6
Bigbore
Kooks
Old July 31st, 2011, 09:38 PM   #13
Chitty Chitty Bang Bang
TheOdessa's Avatar
2001 Mustang GT
TheOdessa has a spectacular aura aboutTheOdessa has a spectacular aura about
Vacuum leaks drive me up the wall
2001 Mustang GT 5-Speed
http://img265.imageshack.us/img265/4601/bulletss.jpg
God Created Man, but Sam Colt Made Them Equal
Old July 31st, 2011, 09:41 PM   #14
2001 Mustang GT
yea honestly i thought it was a bad weld in the elbow because the leak wasn't there before... but i guess from reusing the old TB gasket it just wasn't good enough so i had to get a new one and no more whistle lol.
Old July 31st, 2011, 09:43 PM   #15
TheOdessa's Avatar
2001 Mustang GT
Cool that it was a simple thing and not something hard. How did you think of changing that gasket? Random or did you use a stethoscope?
Old July 31st, 2011, 09:44 PM   #16
2001 Mustang GT
hope you bought the edelbrock fuel rails. if not good luck lol and i hope you plan on spending a decent amount of money on fuel line fittings lol... but worst come to worst if that nitrous plate wont allow the set up to clear the hood the Edelbrock manifold already has a drilled and tapped hole right under the elbow mount for a nitrous set up( i just bought a plug and plugged mine).. but that's just something to think about. but you will see for yourself when it gets there lol... there are plenty of twists and turns to get that manifold to work properly with the stock set up. lol
Old July 31st, 2011, 09:46 PM   #17
2001 Mustang GT
haha i ran my hand over like everything in that area and the noise changed when i moved my hand closer to the top of the throttle body where it mounts to the elbow. because obviously the whistle noise would change if i was deflecting or blocking the air getting sucked through the leak lol
Old July 31st, 2011, 09:57 PM   #18
MikeJones's Avatar
13.7@103
When the time comes, I'll order the fuel rails.
Mod6
Bigbore
Kooks
Old January 1st, 2012, 01:01 PM   #19
skidad62's Avatar
2003 Centennial Edition
skidad62 will become famous soon enoughskidad62 will become famous soon enough
Sent you a PM - looking to do a similar conversion on my supercharged set up.
Vortech YSI driven MMR 1000
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/227869-6061-elbow-installed.html
Thread Hurricane, rails and 6061.com elbow | Corral.net: Ford Mustang Forums | BoardReader This thread Refback April 5th, 2012 11:52 PM
Threads Similar to: 6061 Elbow Installed!
Edelbrock Victor jr. w/ 6061 elbow... BakerFX4 99-04 56 November 14th, 2010 01:18 PM
Pcv elbow Mustang03 99-04 3 February 19th, 2010 08:26 PM
Installed Carbon Fiber Inlet Elbow 07stanggt 2005 - 2010 20 April 5th, 2008 10:21 PM
