Remove Automatic Shift Knob
I got a new automatic shift knob for my 2000 GT (AOD) but I cannot figure out how to remove the stock one. There is a small hole on the front of the shifter, but because of its location, I cannot tell if there is a screw in there and what shape/size it is. I tried using eyeglass repair screwdriver but it didn't catch anything so it's either to small or there isn't anything in there. Can anyone help with this? I appreciate it.
2000 GT Covertible (AOD) 19" Konig Appeals w/ Dunlop SP9000, Eibach Pro Kit, Baer 13" Brakes, Powder-coated red calipers, Flowmaster 40s, HID upgrade, Billet Grill, Red interior trim, Pioneer AVIC-N3, JL 10W7 in custom box, JL 500/1 |
I believe that there is a clip in the back that is recessed that resembles a staple.
pull that out(a flat head should work) and it should come off. as for installing... it is the same way unless you have an OD button.
My shift knob has the overdrive button on the side. I removed the tiny set screw in the back of the knob, finally, but now I can't pull it off the shaft. I've pushed the selector button in and I've pulled and pulled and it won't budge! Help please!
Im not sure what the problem is.
maybe someone with an auto can help you. I will give you this tid bit of info though. be careful with the OD button when you do get the shifter off. you don't want to tear those wires and does your aftermarket one even have a button for OD?
yeah i bought an overdrive relocation kit...hopefully someone can help out otherwise i'll call the company on monday and see what they say
what kind of shift knob is it..i didnt even know there were some out there for automatics..can you post link
#7 | |
This should help redpony http://www.uprproducts.com/PDF/New_I...%20Install.pdf or this one http://www.uprproducts.com/PDF/New_I...%20install.pdf both are the same just different header
![]() ________________ JLT CAI, Accufab 70MM TB/Plenum,Xcal 2/BamaChips Tune |
Any luck? Let us know...
i bought the first product (first link), which took 7 weeks to receive by the way incase anyone was thinking about ordering. I tried following those directions but the step that says after the screw is out, push the selector button in and the handle will lift off, well that doesn't happen. I've wrestled with it and it does not budge! I'm not sure what to do!
Did you move the gear selector to 1st gear and then try to remove the handle?
I just ran outand tried it on mine and it came right off.
yeah i followed the directions exactly...pulled the handbrake, shifted to first, pressed in the selector knob and lifted up, its stuck! That's really odd.
Well that sucks...I tried
thanks 1sttimeford, i appreciate your help, hopefully upr will be able to clear it up
anytime
Any luck?Let us know
i called both ford and upr and they said it should come right off, which it doesn't, so i'm going to try to swing by the ford dealership tomorrow and see if someone can help me out. i can't believe how difficult this is!
dude .. where in NJ are you?
finally after struggling for a few days, I took it to the ford dealer, and like I feared, the guy yanked the handle off and ripped the overdrive wires. It was gonna cost $25 for a new overdrive button, so I was like screw it and I went to radioshack and bought a $3 toggle switch to which I wired the overdrive. So finally after all that headache, I have my new shift knob, and an extra toggle switch, although now I have an overdrive relocation kit available, if anyone is interested. Thanks for all your help guys. After I receive my boot, I will post pics.
so you went to FORD
FORD broke your part AND made you pay for it? am I correct?>
Proud American
Yeah make those assholes pay for it if they broke it!
Threads Similar to: Remove Automatic Shift Knob
| LED Shift Knob | katsulas | Visual | 9 | November 12th, 2007 05:13 PM |
| Leather Shift Knob | Drick | Visual | 4 | October 8th, 2007 02:00 AM |
| SHIFT KNOB | stanged out | V6 Mustangs | 2 | March 1st, 2007 05:37 PM |
| Which Shift Knob | o3gtdgs | 99-04 | 7 | November 19th, 2006 11:41 PM |
| Shift Knob | o3gtdgs | 99-04 | 2 | October 9th, 2006 04:29 PM |
