02GT install questions?
Old May 20th, 2007, 03:07 AM   #1
docbelasco's Avatar
docbelasco is on a distinguished road
Send a message via AIM to docbelasco Send a message via MSN to docbelasco Send a message via Yahoo to docbelasco
So, next Sunday I'm buying a 02GT(31k miles) with the wiring harness, ecm, and hopefully the gauge cluster too. I want to drop it in my 97GTvert. My 97GT engine only has 98k and running perfect, thus I want to build up the 02GT engine before I plug it in.
These are the current mods to the 97GTvert:
MAC CAI w/ K&N air filter
83mm C&L MAF
75mm Accufab TB(going to get matching Accufab Plenum soon)
Bassani X-Pipe w/ cats
Standard 40's turned down before axle
97 Cobra rear axle w/ new 3.73 gears, rotors, brakes, etc...
PBR Cobra front calipers/rotors, etc...
Uninstalled:
Sub Frame Connectors
Xcal2 (going to buy wideband&gauge from jgorm soon)
Front&Rear double drilled & curved slotted rotors(waiting to find the best non-squeek pads)
Will my current transmission be compatible with the 02GT engine? Do I need other parts? What kind of transmission do I have now? t-45....? I was thinking of getting a Billet Flywheel before the swap...
Will I need to buy a new exhaust system for the 02 engine?
Will I need to use the 02's Gauge Cluster when I swap the engine? Do I need to legal document/notify the DMW of the engine swap?
What mods/parts can I use on the 02 engine that I currently have on my 97.
Am I forgetting anything? Advise please.....
oh, next year I'm thinking of twin turbo the 02 engine, or should I just take the heads off the 02 and put them on the 97 and then twin turbo?
damn, I should have skipped Med-school and became a mechanic....
Threads Similar to: 02GT install questions?
Nitrous Install Questions Speedstang302 General Tech 6 November 3rd, 2007 11:17 AM
Some questions for a Sound system install, lil trouble Timmano The Clubhouse 23 October 21st, 2007 03:45 PM
MIL install SPF0percent General Tech 1 September 20th, 2007 03:03 AM
Fuel injector install questions? bossman2kgt 99-04 7 July 12th, 2007 04:14 AM
What would it take to install this... Nick_Rapitis V6 Mustangs 18 May 18th, 2007 10:32 PM
