#21 | |
Thanks |
#22 | |
The cause I have found is that if you hit a bump and you feel the steering wheel steer without any input that is a bumpsteer issue basically. The good ones are either Maximum Motorsports or Steeda seem to be the better kits to go with. Hope this helps out.
![]() Sig by Tricep |
#23 |
Here is a bumpsteer kit pic on the end of the powersteering rack.
#24 | |
#25 |
2000 mustang gt vert
am i the only one that noticed he said he measures ride height from the ground to the fender? measure it from the center of the wheel to the center of the fender opening. secondly check your bushings and all other suspension components. a bad or slightly bad control arm bushing will cause more then desirable flex suspension flex (aka tire rub) squeaking, and clunking noises.
#26 | |
#27 | ||
but hopefully you fixed your issue by now anywyas |
#28 | |
Threads Similar to: H and R super sport lowering springs problem, PLEASE HELP!!!
| H&R super sport springs | brody904 | 99-04 | 40 | June 20th, 2011 11:10 AM |
| H&R Super Sport springs | WNTS 2RN | 2011+ | 14 | March 4th, 2011 01:52 AM |
| H&R super sport lowering springs | Mighty Stang | 99-04 | 2 | March 3rd, 2011 08:48 AM |
| H&R Super Sport springs | WNTS 2RN | Pictures | 6 | February 25th, 2011 01:44 AM |
| H&R super sport springs! | stangliter04 | General Tech | 10 | March 16th, 2006 10:49 AM |
