how long will these headers take?
Old September 3rd, 2011, 03:29 AM   #1
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
Just curious what I should expect for install time on my longtubes. I'm assuming 6 hours or so unfortunately lol. I'm planning on dropping the kmember first thing, will i have to remove motor mounts for anything? I have an engine support, air tools, etc. hopefully these flowtechs mount up alright and dont leak
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old September 3rd, 2011, 03:42 AM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
Sqirt some copper rtv around the gaskets. Re-use the stock studs and use oem gaskets and you will have no problems with leaks
bone stock from the factory!
Old September 3rd, 2011, 06:48 AM   #3
I Hate Convertibles...
2000 GT Vert
JoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to behold
Send a message via MSN to JoshC!
talk with zinc-vert02 about his flowtech install. it wasnt as straight forward as he thought it would be.
Im topless, are you?
Topless Mustang Club Founder
Black Stang Crew Member #boobs out
mods/pics
Old September 3rd, 2011, 07:31 AM   #4
Bullitt5566's Avatar
2001 Mustang Bullitt 5566
Bullitt5566 is on a distinguished road
If this is your first time dropping the k member I'd be ready for the unexpected, so 6 hrs x2. The motor mounts will have to come off so you can get at the header bolts. I'd also have a 7/16 ratchet wrench and 1/4 drive socket set with extentions and swivels. I had to grind the starter base to get it to fit with my MAC longtubes. Also make sure you have the O2 extensions and install them BEFORE putting the long tubes on, otherwise you'll have to try and get your hand between the block and headers. It isn't hard, just time consuming.
True Blue Bullitt 517hp 456tq
Vortech
| Aftercooler | MHS Blower Cams | MAC LT | Lethal Xpipe | SLP PowerFlo | MM RCA TQA PHB FLSC
Old September 3rd, 2011, 10:09 AM   #5
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
Flowtechs aren't the best fitting headers for our cars and if this is your first time it will take much longer than 6 hours. I decided to have a shop do my longtubes. The ARH's fit perfectly with no clearance problems. Car was ready 6 hours after I dropped it off.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old September 3rd, 2011, 11:23 AM   #6
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
wow shouldn't take any more than six...
definitely connect your o2 extensions before installing the headers as stated. if your trans cooler lines are as close as mine were i'd recommend wrapping a little heat tape around them.
cams + 150 shot
Old September 3rd, 2011, 12:50 PM   #7
86er's Avatar
personally I dont drop the K member anymore. If you have a cherry picker to hold the engine up, undo the trans mount, put a jack under it and you have more than enough room. Just remove the engine mounts and you can do them just like that. Thats how I do it
Just a truck
Old September 3rd, 2011, 01:03 PM   #8
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Doing it with the K in is such a pain... Sure dropping the K will take a couple hours, but it saves you from the frustration of trying to get the nuts on the studs with no room.
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old September 3rd, 2011, 02:52 PM   #9
11.85@116
It took me 40 minutes to drop the k and every thing is RIGHT there. I would never try this without it. But all the old parts are off, headers are bolted up. I had to run to get a plug for the egr, gotta put that on then put the kmember back up. No clearance issues thus far. I dropped the motor about 2 inches tho so hopefully there's no issues when it's up again. I've got 3 hours into this so far and could have it done in an hour if I could get one of my lazy ass friends over to help me with this mobstrosity that they call a kmember lol
Old September 3rd, 2011, 03:34 PM   #10
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
shoulda done a tubular k at the same time
cams + 150 shot
Old September 3rd, 2011, 04:40 PM   #11
86er's Avatar
actually its not a pain, its a cake walk, and it doesnt take a few hrs to drop the k member, 30 min tops
No sense in doing more work aka dropping the K when you can do it with just undoing the mounts and supporting the drive train
Just a truck
Old September 3rd, 2011, 06:42 PM   #12
11.85@116
well it took about 5 hours to get it all done and on. about a half hour of that was spent heating and bending the xpipe because it was about an inch too narrow and i couldn't connect them to the headers. but all in all it wasn't too bad. the headers themselves fit great, no issues with them at all plenty of clearance around the trans, starter, stearing shaft, etc. just their xpipe sucks. it does seem to feel faster now, and also sounds way different, in a good way i think. maybe now i can get that 12.x on motor lol.
Old September 3rd, 2011, 06:50 PM   #13
11.85@116
Old September 3rd, 2011, 07:02 PM   #14
8.7 1/8 mile
mwilly is on a distinguished road
Yeah dude dropping the K is the way to go. Good job on the install man, sounds like everything went relatively smooth. I think LT's make the cars sound a lot better. Did you lose any low-end torque?
Old September 3rd, 2011, 08:37 PM   #15
Nice install. Interesting how different headers have different tube routing paths.
Vortech
Old September 3rd, 2011, 09:47 PM   #16
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
how bad was tigtening the nuts on the passenger side?? i remember on the mac's there was one on the passenger side that was just an absolute pain. i think it was the second one back from the front on the top...had to use a crows foot. couldn't fit a wrench up there.
cams + 150 shot
Old September 3rd, 2011, 11:07 PM   #17
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
thats because he didnt text me enough to get my pointers
Old September 3rd, 2011, 11:09 PM   #18
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
I hope you didnt use the gaskets that came with the headers
Old September 3rd, 2011, 11:14 PM   #19
2000 GT Vert
did you have the same issues with fitment as him?
mods/pics
Old September 3rd, 2011, 11:15 PM   #20
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
nope, mine went in without a hitch. I just dont think he had everything set right when he put it back together
Threads Similar to: how long will these headers take?
Shorty headers vs. Long Tube Headers 2000stallion V6 Mustangs 10 April 19th, 2011 01:15 AM
Long Tube Headers scxc15 99-04 20 January 26th, 2009 06:17 PM
(2005-2008)Long headers vs shorty Headers RetroKid V6 Mustangs 9 April 12th, 2008 12:14 PM
Long Tube Headers NottyBoy93 General Tech 4 April 9th, 2007 10:13 AM
Long Tube Headers NottyBoy93 5.0 Mustangs 10 April 8th, 2007 04:58 PM
