Rear Main seal
Old September 3rd, 2011, 10:49 AM   #1
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
Rear Main seal
Since I have so much going on at the time I did not notice when installing the rear main seal does the seal go flush with the outside of the rea main seal casing or does it hurt for it to be recessed inside the casing? I am second guessing myself at this point, but I installed ine about 1/8 inch recesed and it looks like it will work just fine, but need some help on this one since it is so hard to get to in the future. Thanks
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old September 3rd, 2011, 12:54 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
I always center my rear main seal with rtv along the side before I slam it in
bone stock from the factory!
Old September 3rd, 2011, 01:50 PM   #3
SSG Pate's Avatar
i didnt use RTV but its close to center!! Should i tap it out and RTV it?
Old September 3rd, 2011, 02:00 PM   #4
stal94gt's Avatar
2003 mustang v6 ;)
slow
You don't need to rtv it. I just do it for the sake of it. Make sure you pay attention which way you install the seal. For some reason the first time I put it in my car totaly messed up and put it in backwards. Had to drop the trans the next day to flip it cause it was leaking.
Old September 3rd, 2011, 02:06 PM   #5
SSG Pate's Avatar
WEll Shit my project is at a standstill cause I dont have the 4 head dowels!!
Old September 3rd, 2011, 02:13 PM   #6
stal94gt's Avatar
2003 mustang v6 ;)
slow
Take them off your old motor.
Old September 3rd, 2011, 02:35 PM   #7
SSG Pate's Avatar
I sold the old motor and forgot to take them out!! So looks like ill be chllin till next week none of the parts houses carry those without ordering them I have called everywhere and even tried salvage yards.
Old September 3rd, 2011, 10:44 PM   #8
stal94gt's Avatar
2003 mustang v6 ;)
slow
You will need the 4 dowels for the heads, 2 for the trans, 2 small ones for the rear main seal housing. Also there is a small fitting behind the water pump that hooks up to the line to the heater core.
Old September 4th, 2011, 12:16 AM   #9
Macunicorn's Avatar
Macunicorn will become famous soon enough
that reminds me I need to swap mine out. It is leaking a bit.
Sig by Tricep
Old September 4th, 2011, 09:01 AM   #10
SSG Pate's Avatar
I am missing all the head dowels, I have ordered them hopefully they will be here next week so I can get this engine put together by the weekend. I have the other rear main seal dowels, but they seem like you need to hammer them in cause they are to tight to put in by hand.
Threads Similar to: Rear Main seal
rear main seal bandity2k00 99-04 15 March 15th, 2011 09:50 PM
Rear Main Seal 02GreyStallion V6 Mustangs 16 January 21st, 2011 01:58 PM
rear main seal Butters93 5.0 Mustangs 6 July 25th, 2010 08:23 PM
rear main seal? marks87gt 5.0 Mustangs 4 April 26th, 2007 05:16 PM
Rear Main seal 1gunner23 5.0 Mustangs 5 May 11th, 2006 11:53 PM
