valve cover breathers?
Old September 3rd, 2011, 02:33 PM   #1
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
what does it take to run valve cover breathers? i have thought about this but not done it yet. i hate having hoses run all over the engine compartment. what issues will i have with it, if any? supercharged motor if that matters. will i need a tune for this sort of thing?
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old September 3rd, 2011, 05:15 PM   #2
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
I've got one on the intake side(driver) Put one one because I didn't want any extra tubing considering I had enough
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old September 3rd, 2011, 07:46 PM   #3
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
Only issue I ever had with running breathers on a boosted motor is it sprays oil mist out. If you only run one filter the other valve cover has to run before the maf or else you will have issues with un-metered air
bone stock from the factory!
Old September 3rd, 2011, 08:40 PM   #4
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Smart man.
There's also the issue of allowing more moisture in, but thats primarily if you do lots of short trips. If you do longer drives then it has an opportunity to burn off any moisture.
Also crankcase vapors technically count against emissions. I highly doubt they do sniffer tests for this, but it's technically part of EPA/CARB regulations.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old September 3rd, 2011, 08:47 PM   #5
Bullitt5566's Avatar
2001 Mustang Bullitt 5566
Bullitt5566 is on a distinguished road
Holy hose, Sinister, what is all that? Inky, I think Stal hit it. The PVC system draws air from one side through the PVC and into the intake. So if you run a breather instead of a hose it will allow un-metered air. I briefly ran a breather without any problem, but it really should run back to the intake before the S/C and after the MAF. I've always wondered pressure is lost through the PVC or elsewhere.
True Blue Bullitt 517hp 456tq
Vortech
| Aftercooler | MHS Blower Cams | MAC LT | Lethal Xpipe | SLP PowerFlo | MM RCA TQA PHB FLSC
Old September 3rd, 2011, 11:13 PM   #6
2000 gt
i guess i'll just not do it, from research other wise i see it's problematic with oil mist getting everywhere. thanks for the advice/pics.
HARDCORE CREW
Old September 3rd, 2011, 11:48 PM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
The way I ran my setup with blow threw maf was the pcv was run into the intake of the sc and a breather on the passenger
Threads Similar to: valve cover breathers?
Questions About Valve Cover Breathers 02'TrueBlue 99-04 23 December 25th, 2010 01:19 PM
Please help need valve cover!!!!! eli t 99-04 4 June 7th, 2010 05:07 PM
Valve Cover Breathers 07 Boss 2005 - 2010 27 April 21st, 2009 02:08 PM
No oil in valve cover? TrAb 5.0 Mustangs 18 May 11th, 2008 10:12 PM
Valve Cover mustang1072 V6 Mustangs 15 March 23rd, 2008 09:30 PM
