check engine light
what does the DTCs codes P0102 and P0113 mean? Keep in mind that they came on after i add a supercharger if that helps or even matters.
They both have to do with the MAF and IAT sensor circuits. Did you unplug them with the key on ? If it runs ok clear codes and retest
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
p0102 is something wrong with your MAF and p0113 has something to do with your aic(don't quote me on the second one)
err what casper said... iat not aic.
yes its running fine and i cleared the codes and they are still coming back up?
Can you not use you stock MAF with a supercharger? |
I'm not sure.
From what I have been told and from what I have read up on you should change out the MAF for a bigger one when you s/c. try borrowing a bigger one and putting it on. if your codes go away that's probably your problem
RLY SRS
No because you ahve a 2002 right?
the IAT sensor is integrated into the MAF...Thus you are throwing the codes... You should be running at least a lightning MAF and a 03 lightning IAT sensor...The gray and grad/red stripe wire are for your IAT... By your name I take it you are running a procharger? More info is needed to fix this for ya... |
yes 2002 gt procharged 10psi intercooled. What is a IAT sensor?
just tell me what info you need.
thanks guys. |
RLY SRS
IAT - Intake Air Temp Sensor...
Did procharger not send you antoher MAF? They usually do... Just give us as much info about the kit that is on your car as you can... Did you buy the kit used? |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
I have a MAF out of a Vortech set-up and the IAT was not integrated into the MAF. I had to cut the wires and solder a plug on to go to the IAT.
#11 | |
#12 | ||
MM's Mad Scientist
Slow Fella
why whats wrong with that?
rmpoutlet is known for jacking up the orders and screwing people
well question? Could the custom tune that they installed in the programmer be screwed up or wrong? and if so maybe that is why my engine light is on.
if they didn't give you a MAF that's more than likely the issue.
Well ok what do i need to get? A lightning one or something different? Also what about this intake air temp sensor? Where is that located on the car and do i need to get one of those?
#18 | |
MM's Mad Scientist
Slow Fella
so the iat is part of the MAF and if i got a lightning one it would have a iat with it?
#20 | |
MM's Mad Scientist
Slow Fella
Threads Similar to: check engine light
| 04 GT check engine light | mustanglover408 | Modular Mustangs | 2 | October 14th, 2007 12:09 AM |
| Check Engine Light | brose1388 | 2005 - 2010 | 4 | April 28th, 2007 04:26 PM |
| 95 3.8L check engine light | nikbait | V6 Mustangs | 3 | February 24th, 2007 03:57 PM |
| Check engine light | ByPopularDemand | V6 Mustangs | 18 | January 9th, 2007 02:50 PM |
| Check Engine Light? | GreenFaleen | V6 Mustangs | 13 | November 20th, 2006 03:26 AM |
