5.0 Stroker or 4.6 for Turbo? - Forums at Modded Mustangs
post #1 of 33 Old September 12th, 2011, 09:54 PM Thread Starter
KCCO
codycat91's Avatar
iTrader: 14 reviews
What the title says... what would be better and why?
Centennial GT Project
My weakness becomes my weapon, and pain my pleasure
Originally Posted by GCubersoldat View Post
I'll buy a Chevy before i go back to MMR.
codycat91 is offline
post #2 of 33 Old September 12th, 2011, 09:56 PM
stal94gt's Avatar
Stick with a 4.6 its cheaper. Also the motor is square with the stock stroke.
bone stock from the factory!
stal94gt is offline
post #3 of 33 Old September 12th, 2011, 09:58 PM Thread Starter
KCCO
codycat91's Avatar
iTrader: 14 reviews
Well I'm getting forged internals, and the stroker isn't really that much more, and I read that a stroker would help a turbo spool faster, but might also limit how fast it can spool? Idk, thats why I'm asking...
post #4 of 33 Old September 12th, 2011, 10:02 PM
stal94gt's Avatar
It may help slightly with spool but a good turbo grind cam will also help. I would stick to stock stroke and if you want to go bigger go bigger bore like the boss block.
stal94gt is offline
post #5 of 33 Old September 12th, 2011, 10:07 PM Thread Starter
KCCO
codycat91's Avatar
iTrader: 14 reviews
I currently have a teksid block and 04 mach one heads with stock cams
post #6 of 33 Old September 12th, 2011, 10:08 PM Thread Starter
KCCO
codycat91's Avatar
iTrader: 14 reviews
Rotating assembly is next on the list
post #7 of 33 Old September 12th, 2011, 10:11 PM
stal94gt's Avatar
I would deff send those heads off and get bronze guides installed along with the even flow head cooling mod
stal94gt is offline
post #8 of 33 Old September 12th, 2011, 10:15 PM Thread Starter
KCCO
codycat91's Avatar
iTrader: 14 reviews
Bronze valve guides on my list... Whats the even flow cooling mod?
post #9 of 33 Old September 12th, 2011, 10:17 PM
stal94gt's Avatar
It helps keep the heat of the 7-8 cylanders by routing water out the back of the head to the radiator line.
stal94gt is offline
post #10 of 33 Old September 12th, 2011, 10:18 PM Thread Starter
KCCO
codycat91's Avatar
iTrader: 14 reviews
How much work is involved in that? And is there a link or a how-to for that?
post #11 of 33 Old September 12th, 2011, 10:19 PM
stal94gt's Avatar
Lethal Performance GEN 2 Head Cooling Mod [LP-GEN2COOLINGKIT] : Lethal Performance, Performance parts for Ford Mustangs
It an easy install. You knock out the freeze plug on the back of the head and install a bung and run a coolant line to the radiator line
stal94gt is offline
post #12 of 33 Old September 12th, 2011, 10:47 PM
BYAHHHH!
Scott2001GT's Avatar
iTrader: 5 reviews
I'd say 5.4 or 4.6.
Powered by Ford
Boosted by Precision Turbo and Engine
Thanks to: Wagon Wheel Performance & STL Mustangs
Scott2001GT is offline
post #13 of 33 Old September 12th, 2011, 11:20 PM
Hooo Ha Ha
sharkbait's Avatar
iTrader: 10 reviews
Id rock a 5.0 stroker with a turbo.
853rwhp @ 23psi
75mm Turbo 5.4 swap E85
#turbo2v
10.11 @ 138mph STOCK LONGBLOCK
9.11 @ 149mph - New Longblock /w Powerglide
www.JPCracing.com 410-729-0005 ext. 11
PM me if you need any parts or advice!
sharkbait is offline
post #14 of 33 Old September 13th, 2011, 12:04 AM
2VSouth's Avatar
iTrader: 6 reviews
I tossed around the idea of a 5.0 stroker, will all come down to cost for me. ModMax sells a nice stroker kit for under 2k, not sure what power youre trying to push but the one I'm talking about is good for up to 550hp. It didnt state if it was fwhp or rwhp however.
2VSouth is offline
post #15 of 33 Old September 13th, 2011, 12:12 AM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
MMR's 5.3L Stroker kit is badass. That guy BobNasty made 393rwhp all motor with that stroker kit, TFS heads, and MHS cams. Some food for thought.
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is offline
post #16 of 33 Old September 13th, 2011, 12:13 AM
Hooo Ha Ha
sharkbait's Avatar
iTrader: 10 reviews
fwhp = front wheel horse power
bhp = break horsepower (the correct term) sorry it drives me nuts.
Also i would buy any rotating assembly thats not good for atleast 700. Cause really if your gonna spend the kind of coin why buy something that can only push a little past stock?
853rwhp @ 23psi
#turbo2v
post #17 of 33 Old September 13th, 2011, 12:42 AM
2VSouth's Avatar
iTrader: 6 reviews
I wouldn't either, just saying, for the price, its not bad for someone not looking to break the bank on a stroker kit.
2VSouth is offline
post #18 of 33 Old September 13th, 2011, 12:50 AM
MMR Mod 900 forged stroker kit is good for 900+HP. They'll even notch the pistons for an aggressive cam for a little extra.
You'll eventually run into a dead end going all motor using the 4.6, but if you do a forged rotating assembly, you always have the security there for FI down the road.
Personally, I would go forged stroker, enjoy the "all motor" bragging rights, once you get tired of that, go FI.
2003 Mustang GT - Whole buncha crazy stuff done to it.
One foot on the gas. One foot in the grave.
GripGrizzly is offline
post #19 of 33 Old September 13th, 2011, 08:16 AM
slow02gt's Avatar
Send a message via AIM to slow02gt
stay 4.6 and just go 20 over....no need to spend money on a stroker...if it would have helped i would have went with 1...all the big name builders talked me out of it because its not needed...your also going 4v so spool would be quick anyway..just do the compression 9:1-9:5......and there is no such thing as slow spooling anymore thanks to billet wheel turbos and since your going 4v there is no need to notch the pistons because there is no need for cams needed that big in a 4v turbo setup anyway..
and yes do the head cooling mod....
a bunch of shit lol..
slow02gt is offline
post #20 of 33 Old September 13th, 2011, 09:24 AM
Yeah, it's not needed, but how could he not benefit from it? I mean, if you look at a forged rotating assembly, and a stroker kit (which is also forged), they're not far from the same price. So, why not?
Human Verification
