#41 |
The reason that I sent my first blower back for a rebuild was because the oil seals were leaking and now I'm going to have to do the same thing with this new one. It only has a one year warranty and I found the invoice and it says Oct 6th so hopefully they don't try to tell me the one year is expired.
Vortech V2 Si
#42 |
12.73@111.36
They shouldn't if you call them tomorrow. It's not been one year yet. I sent my head unit back to ProCharger after 2 years and 10 months and they replace the main seal for free under their three year warranty. It had around 65,000 miles on it. Be sure to call them so they have a record of it before the warranty expires.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#43 | |
If you changed the pulley on the unit i wouldn't bother sending it in. They will just charge you to ship it back, unless you pay to repair it. The warranty only covers the original pulley, from what frank told me at vortech when i asked about the warranty after a rebuild he told me that they secretly mark the unit and the pulley so they would know if it was changed. I asked because i was going to do a rebuild, but didn't want the warranty to be voided since i was using a 2.87, and he told me with that pulley there is no warranty.
2000 GT, 5.1L, Crank, Probe 23cc Pistons, Manly H-beam Rods, Arp Studs, Ported heads, Comp Cams XE270AH, 75mm TB, Plenum, Vortech v1 T-trim, Custom FMIC, Roush Stage 3 Kit w/rims, Spintech Mufflers, 3.73's, 60lbs inj, Duel GT pumps, SCT Maf. |
#44 |
12.73@111.36
That is the same with ProCharger. To have the warranty you cannot change the pulley.
#45 | |
Vortech V2 Si
#46 | ||
As long as you have everything in writing they are legally obligated to fix it. Good luck. For reference to what i'm talking about i found this for you. Frank is the main guy at vortech. http://www.modularfords.com/forums/f...ilemma-129087/
2000 GT, 5.1L, Crank, Probe 23cc Pistons, Manly H-beam Rods, Arp Studs, Ported heads, Comp Cams XE270AH, 75mm TB, Plenum, Vortech v1 T-trim, Custom FMIC, Roush Stage 3 Kit w/rims, Spintech Mufflers, 3.73's, 60lbs inj, Duel GT pumps, SCT Maf. Last edited by mat82284; October 3rd, 2011 at 07:38 PM. |
#47 |
No I didn't get it in writing. If they lied about it I just won't buy anything from them ever again and make sure to post that there are liars working for them. I went from a 3.6 to a 3.33 pulley.. it shouldn't start leaking just because of that. I have read countless posts about vortech units leaking because of the crappy seals they use in them and I believe all of them now. Also there is no mark on the pulley or headunit.
Vortech V2 Si
#48 | |
#49 |
If you changed the pulley and removed the factory nut cover the warranty is only 1 year not 3 years. I doubt they will warranty it. It says specifically in your warranty information...
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
#50 | |
Yes it's only been a year.. not 3 years. They didn't give me any warranty info so it doesn't specifically say anything.
Vortech V2 Si
#51 | |
Hopefully not though, if the supercharger is fine, they will charge you a diagnostic fee and make you pay for return shipping. That would suck .
#52 |
I haven't sent it yet because I'm not sure that it's leaking or if it is it doesn't seem like that much. If there was oil in the intercooler how would it make it all the way back up the pipes and into the blower?
Vortech V2 Si
#53 |
I Poop Entirely Way Too Much
Blown 03 GT
The air blowing of the oil would pull some up, it wouldnt be alot but definately some.
Threads Similar to: new vortech already leaking oil
| vortech leaking oil | hardhitter | 99-04 | 10 | July 12th, 2010 12:00 AM |
| Vortech Oil Supply Brass fitting leaking | Shaun03GT | 99-04 | 56 | March 12th, 2010 08:47 PM |
| Pics of my Vortech - Need help from you Vortech guys!! | stanglifemike | 2005 - 2010 | 29 | September 12th, 2009 10:52 PM |
| Vortech & Cams OR Vortech & After/Intercooler | StuTheMusicEngineer | 99-04 | 21 | January 4th, 2009 10:51 PM |
| Leaking Again | UTGT | 99-04 | 11 | March 3rd, 2008 11:52 AM |
