Royal Purple
Old May 22nd, 2007, 08:28 PM   #1
HessiaN257's Avatar
13.9@101
HessiaN257 is on a distinguished road
Royal Purple
Its about that time I have to change my oil, and I have only heard good things about Royal Purple. How is royal purple in our GT's? All types of feedback would be appreciated.
13.9@101 before some mods
Old May 22nd, 2007, 08:51 PM   #2
Proud American
MustangMatt96GT's Avatar
I am going to use it next time I change my oil! I think it would work just fine!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old May 22nd, 2007, 09:08 PM   #3
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
i always use castrol syntec. i use royal purple for all of my other fluids.
Old May 22nd, 2007, 10:07 PM   #4
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
royal purple works great in our cars, thats all i put in mine now.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old May 22nd, 2007, 10:09 PM   #5
ATLmustang is on a distinguished road
i wouldnt use it if i had alot of miles, other than that i think its good oil
Old May 22nd, 2007, 10:34 PM   #6
RC02GT's Avatar
2006 Saleen s/c
RC02GT is on a distinguished road
Send a message via AIM to RC02GT
i have mobil 1 fully synthetic, can i switch over to royal purple because i heard when you go fully synthetic you cant switch back, just wana check if there will be any problems with switching synthetic name brands
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune
Old May 22nd, 2007, 10:57 PM   #7
Achieving more N/A power!
gills99stang's Avatar
When this baby hits
88 miles an hour...
gills99stang will become famous soon enoughgills99stang will become famous soon enough
Send a message via AIM to gills99stang
Royal Purple is a synthetic oil. I put it in just last week when I changed my oil and haev no complaints so far. With any motor oil, it's hard to tell the difference yourself, unless you talk to a shop that does engine rebuilds, then they can tell you the effects of different motor oils inside the engine.
I've also heard that Royal Purple has been "dyno tested" vs. other synthetic oils and that RP had HP gains over the others.
http://www.royalpurple.com/techa/whyrpa.html
Brendan
'99 Mustang GT [ 318 rwhp N/A ] - SOLD ()
'04 F150 XLT SuperCab
Old May 22nd, 2007, 11:18 PM   #8
MM's nicest mod, :)
actually there is a company you can send your oil off too once you change it and they will tell you if it broke down or not and if its good oil
Old May 22nd, 2007, 11:20 PM   #9
When this baby hits
88 miles an hour...
No shit? That's really cool. Is it worth it to send it off? Would you only do it if you suspected something wrong in your engine?
Brendan
Old May 22nd, 2007, 11:21 PM   #10
zkid01 is on a distinguished road
Yep Yep... Royal Purple is the only thing that has every touch my baby! Its a great oil. And yes you can switch from mobil 1 to Royal Purple without any problems... if you were using a reg oil i wouldnt recommend it if you had more than 60K on the car.
Work Hard....Play Harder.
Old May 22nd, 2007, 11:25 PM   #11
Proud American
But since your car has had synthetic run through it already, the mileage doesnt matter does it? And also where are you guys buying your royal purple and what weight are you guys running?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old May 22nd, 2007, 11:27 PM   #12
When this baby hits
88 miles an hour...
I run 5W20 and the only place around where I am that seems to stock it is NAPA. It's about $7 a quart. I use it along with a Mobil One oil filter.
Brendan
Old May 22nd, 2007, 11:30 PM   #13
Proud American
Yeah the only place I havent looked for it at, because they have a inconvient parking lot, but I will stop by there and pick some up next time I change my oil. Because of my climate do you suggest 5W30 or 10W30? Thanks
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old May 22nd, 2007, 11:33 PM   #14
If you have a little higher mileage i would run 10w30.. also i think that is what is recomended for your year stang..
Old May 22nd, 2007, 11:35 PM   #15
Proud American
Yeah thats what I have in it now so I think I will just stick with that! I have a 122K
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old May 23rd, 2007, 11:53 AM   #16
winter i would run 5w30 and summer months i would run 10w30.
Threads Similar to: Royal Purple
Royal Purple ???? theyanks904 V6 Mustangs 5 July 27th, 2007 02:28 PM
Mobil 1 VS Royal Purple Youngin The Clubhouse 13 July 24th, 2007 10:37 PM
Royal Purple ozan169 2005 - 2010 6 February 4th, 2007 01:02 AM
Where 2 Buy Royal Purple Online 4point6GT 96-98 18 October 11th, 2006 08:47 AM
Royal Purple GTSilver 99-04 2 August 25th, 2006 09:56 PM
