grinds into 3rd, hard to get in 2nd
Old May 22nd, 2007, 07:46 PM   #1
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
I'm new to the forum and was trying to find someone with the same type problem but couldn't. Can anyone help. 1st is fine but shifting into 2nd it feels like it doesn't want to go in. and then into third just trying to go it grinds...but if i delay and push to the right it usually goes in fine. 4th and 5th are fine. But i was wondering if anyone knew what could be wrong before i take it to a shop?
Old May 22nd, 2007, 07:48 PM   #2
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
mine does it too, i even changed the fluid but it still does it!! just a stiff transmission i guess
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old May 22nd, 2007, 07:56 PM   #3
11.21@123 -150 shot
orangeRcode is on a distinguished road
sounds like the synchros are bad. It is more difficult to shift at higher rpms? Could also be a bent shift fork. Synthetic fluid may help a bit but it is not going to cure the problem.
Welcome to MM. Post some pics of your car.
Old May 22nd, 2007, 08:00 PM   #4
DrHolliday is on a distinguished road
Mine does the same thing. I'm planning on changing my fluid soon. I read in an old post that the B&M ATF works really well in our trannies.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old May 22nd, 2007, 08:29 PM   #5
SteviGX's Avatar
I'm gonna try and get some pics up soon. Thankx for the welcome orange. I was planning on getting an MGW shifter didn't know if that would help at all.
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
Old May 22nd, 2007, 08:40 PM   #6
1Badsnake's Avatar
2003 Mustang Cobra
1Badsnake is on a distinguished road
What kind of mustang do you drive? The first order is to assess you fluid level and whether or not there is presence of metal debris. More than likely your gears or syncros are either going bad or gone. The repairs could be costly so research purchasing a new set of gears and upgrading you mechanisms. Hope this helps. If I knew the model I might be able to help more. Another obvious point is when shifting is you clutch fully depressed. I know this sounds silly, but my wife did that on my last mustang gt and it was a simple fix I told her she couldn't drive it anymore. HAHA.
Old May 22nd, 2007, 08:45 PM   #7
ujslost's Avatar
well since its a manual you cant drop the tranny pan unfortuantly. But you need new synros (blocker rings)
Old May 22nd, 2007, 08:51 PM   #8
SteviGX's Avatar
It's an 02 GT prolly shoulda said that waaaay be now. So syncro's you think?
Old May 22nd, 2007, 08:53 PM   #9
1Badsnake's Avatar
2003 Mustang Cobra
I mentioned before about the tranny pan. I had a manual and swapped it out for an automatic for racing. Sorry for the mix up.
Old May 22nd, 2007, 09:16 PM   #10
OcOnnor220 can only hope to improve
When I bought my 2001 gt, the difference in the gear-box throw, clutch depression and gear power from my 96 gt was substantial. Shorter throw, more power outta every gear and a better hold with the clutch...but these cable clutches ARE stiff. NOBODY is more anal about perfect shifts in their 2001-2004 GT than me after already replacing a clutch in my old one. I NEVER even use first gear in this car unless Im pulling out of a parking space...because the gear is so short and the car so powerfull, feathering from 2nd 95% of the time can safely be your new method...worked for me, my GT has 110,000 on it with no clutch service and Ive never had a problem driving it like that.
Old May 22nd, 2007, 09:16 PM   #11
ujslost's Avatar
thats understandable
syncros or shift fork , but my bet is on synchros
Old May 22nd, 2007, 09:17 PM   #12
And yeah, it sounds like bad shifting has screwed up your syncros..
Old May 22nd, 2007, 09:23 PM   #13
SteviGX's Avatar
alright. Thanks for the help guys. much appreciated and i second the bad shifting. alot stiffer clutch than my classic mini had.
Old May 22nd, 2007, 09:28 PM   #14
SteviGX's Avatar
and can you install syncro's? or do you need a shop too?
Old May 22nd, 2007, 09:56 PM   #15
Proud American
MustangMatt96GT's Avatar
Talk to white99stang and ask him what syncros he put in! His have held up to 600 RWTQ and thats amazing!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old May 22nd, 2007, 09:59 PM   #16
Achieving more N/A power!
gills99stang's Avatar
When this baby hits
88 miles an hour...
gills99stang will become famous soon enoughgills99stang will become famous soon enough
Send a message via AIM to gills99stang
Are you guys using synthetic tranny fluid? That should help a lot.
SteviGX, I hate to say it, but it sounds like you might have some transmission repair in your future.
Brendan
'99 Mustang GT [ 318 rwhp N/A ] - SOLD ()
'04 F150 XLT SuperCab
Old May 22nd, 2007, 10:09 PM   #17
SteviGX's Avatar
That is sure what it's sounding like...i got a warranty though. but boy, not having it for a couple weeks or however long is gonna suck
Old May 22nd, 2007, 10:29 PM   #18
superbeef1000's Avatar
wow thats crazy mine dose the same thing eccept i just installed a new clutch and pilot bearing and through out bearing, but mine make a grinding noise only when the clutch is ingaged and sometimes when i do high rpm shifts it is like the shifter is realy hard to move around and get in any gear and other times its fine its kinda got me stumped i was thinking the input shaft retainer and bearing but i dano ..oh and its a 3650 5 speed by the way
Old May 22nd, 2007, 10:41 PM   #19
energiesource's Avatar
energiesource is on a distinguished road
mine takes a few tries to shift into 2nd and reverse, would that be my clutch or what
Old May 23rd, 2007, 07:33 AM   #20
SteviGX's Avatar
mine strugles to get into reverse sometimes and i go through all the gears and it sometimes stops but usually its two or three try's. and mine is when the clutch is fully engaged...to the floor with a stall before shifting into 3rd.
Threads Similar to: grinds into 3rd, hard to get in 2nd
how hard would it be? AFtriathlete 99-04 13 September 19th, 2007 04:14 PM
T-5 Grinds second Drick 5.0 Mustangs 8 September 18th, 2007 01:17 PM
91 GT DOWN HARD SALEEN525 5.0 Mustangs 3 April 24th, 2007 11:26 PM
T5 Grinds Going Into Reverse, Forward Gears Okay 83 5.0 5.0 Mustangs 11 October 22nd, 2006 10:08 PM
starter grinds johnnyboy General Tech 8 July 14th, 2006 01:12 PM
