Ok Two Questions for you! Cluster and Radiator Light
Old May 23rd, 2007, 01:14 AM   #1
1999 Mustang Gt
0di3 is on a distinguished road
Send a message via AIM to 0di3
Ok first things first
i have a 99 gt
the radiator sensor went out (the yellow trash can popped up on my cluster). I know the sensor went out for a fact because i ran a test on my portable computer and it came up with no error codes. Anybody know what sensor i need to get/have a link. I went to ford and the mentally challenged guy behind the desk sold me the wrong sensor...
next...the cluster haha
so initally what happened was i got an overlay kit and had a shop install it on the stock cluster, i didnt like it so i had them take it off and the needle fell out for the speedometer
it was off by about 9 mph and i ended up buying a used cluster off ebay (white face to replace it). it would start with the new cluster so i swapped circuit boards on them. It was still 9 mph off, and now my rpm gauge is off by around 300-500 (high).im wondering what the best way to fix this is.
i have a hyptertech III programmer if that helps, i just bought some 18" black deep dish bullits with 255 tires and changed the settings on the programmer to 25 inch ride height. also, on a side note it seems that once i use the programmer, it seems work with those settings the first time i drive it, but then seems to switch back to the stock ones (but im not sure)
my nearest ford dealership said they dont recalibrate and every other place is expensive as hell
hopefully its possible to fix
thanks in advance
Old May 23rd, 2007, 08:19 PM   #2
02steedagt is on a distinguished road
Send a message via AIM to 02steedagt
http://www.mustangworld.com/ourpics/fcar/whtf1.htm
they tell you how to adjust the speedo in this article. you have to actually pick up the needle and move it... you don't do it with the computer.
"America is all about speed. Hot, nasty, bad ass speed."
Eleanor Roosevelt, 1936
Threads Similar to: Ok Two Questions for you! Cluster and Radiator Light
99 mustang gt radiator light is on! heeeelp 0di3 99-04 6 October 16th, 2007 11:10 PM
gauge cluster light blazor V6 Mustangs 6 July 10th, 2007 09:01 PM
swapping '95 V6 gauge cluster to a '94-'98 GT cluster? Alocatelli V6 Mustangs 3 April 4th, 2007 02:38 PM
HID Light Questions Youngin V6 Mustangs 37 January 21st, 2007 09:54 PM
new gauge cluster install problems plz help theft light bigpopaz99 V6 Mustangs 22 December 15th, 2006 02:29 AM
