Remove/install needles help
Old September 26th, 2011, 11:53 AM   #1
.:sick_stang04:.'s Avatar
2004 4.6L V8 Mustang GT
.:sick_stang04:. is on a distinguished road
Exclamation
hey guys, i wanna start a project to change the color of my gauges, but i need to pull the needles off the gauges first.
whats the best way to pull the needles off without breaking them, but mainly how do i then reinstall them and make sure theyre still acuurate.
.: Drive Fast, Take Chances :.
Old September 26th, 2011, 01:44 PM   #2
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
First, draw a detailed picture of each gauge with the motor running so that you can get the needles back on in the same place. I used a kitchen fork to remove the needle. It allows you to pry up from underneath. All of the needles push back on in the same as the pictures except the speedometer. You have to have the wheels turning to get the speedometer needle back on in the correct place.
I jacked the car up with the wheels off the ground to get the speedometer needle back on correctly. You have to put your odometer in dealer test mode. I ran the car up to 20 mph and then put the speedometer needle on at 20. Using the dealer test mode my speedometer is only 1/2 mph off and the tach is dead on. The link below explains how to put the odometer in the dealer test mode.
BULLITT Archive Mustang Instrument Test Mode
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old September 26th, 2011, 01:51 PM   #3
do you put the other needles on when the cluster is outside the car? or do you reinstall it, let the car run and warm up, then put all the needles back on?
Old September 26th, 2011, 03:24 PM   #4
12.73@111.36
Put the needles back on after the cluster in the car and the motor in the same condition as when you drew the pictures. If they are in the wrong place you can pop them off and put them back on.
Old September 26th, 2011, 03:26 PM   #5
2005gsxr123 is on a distinguished road
just pop em off its easy
Old September 26th, 2011, 03:29 PM   #6
cool...thanks for the tip, ill try that...and awesome link, thatll really help.
Old September 26th, 2011, 04:45 PM   #7
12.73@111.36
Just remember, your wheels must be turning to get the speedometer needle on correctly. If you just snap it back on at zero your speedometer will be 7 mph off. There have been numerous threads from people who thought they had gears but actually the previous owner put the needle back on wrong. How I know this is the previous owner of my car did the same thing.
Old September 26th, 2011, 05:14 PM   #8
13.91 @ 102.04
02'TrueBlue will become famous soon enough
+1 to using a kitchen knife to get the needles off. I used 2, one on each side so it was an even force pulling upwards. also I forget exactly how, but i did it...theres a method of using a 9 volt battery to get the needles back into spec. Basically you attach a 9V to the prongs on the back of the gauges and they go to the middle, so you put the needle on facing the middle/top and it'll be accurate
TRUE BLUE CREW MEMBER #6
Old September 26th, 2011, 05:25 PM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
dont push the needles down to hard cause you can bottom them out
bone stock from the factory!
Old September 27th, 2011, 02:48 AM   #10
fastbike02's Avatar
1999 Mustang gt
fastbike02 is on a distinguished road
I used a fork also and I got out on the highway and with the help of a gps I set my speedo needle dead on
Old September 29th, 2011, 12:16 AM   #11
finished! looks awesome, and i got the needles back exactly on
Old September 29th, 2011, 12:18 AM   #12
any way to open up those buttons below to match the color? i doubt it....looks like theyd break if i try to take them apart
Old September 29th, 2011, 07:14 AM   #13
03OFP's Avatar
2004 Mustang Gt
Unknown
03OFP is on a distinguished road
Kind of thread jacking here... but what stereo/head unit are you using? That looks sweet.
04 GT, Vortech V-3, Hi-Tech Stage 2 Cams, BBK shorties, ProChamber mids, SLP LM1's, FRPP aluminum D/S and 3.73's, Acufab upper plenum, 75mm TB, 75lb/hr FIC injectors
Old September 29th, 2011, 08:03 AM   #14
Beerdog80's Avatar
1995 Cobra/1983 GT Vert
Beerdog80 is on a distinguished road
what color are the needles? And you should be able to open up those buttons and replace the led with a 3mm one of your choice. I'd get a junk yard one to test it one first though.
Old October 3rd, 2011, 09:35 PM   #15
Its the Pioneer AVIC-X930BT...its nice, i paid 800 installed....i spent a long time trying to find a kinda more oem stockish looking radio in the car..most of the aftermarket radios ive seen are too flashy for me...its awesome too, you can customize the startup picture when the radio turns on, so i designed the mustang logo in photoshop and now it kinda reminds me of a bmw or mercedes how the car always shows the emblem when it starts up
Old October 3rd, 2011, 09:40 PM   #16
i didnt change the needles, kept those red but changed the dials amber...the pic i posted doesnt have the needles installed tho, that was just after i finished with the lights...just wanted to see how it looked.
good call with the junk yard tho, im gonna head down to pick-a-part tomorrow and see if i can find one of those buttons...that way i can rip that apart and see if i can change it without messing up my car..thatd be nice to get everything matching...its not a huge deal if everything is amber, and i just have those 3 small green lights, but it is a little annoying.
Threads Similar to: Remove/install needles help
Do i need to remove seat belts to install rear speakers? v6dave 99-04 4 March 2nd, 2012 04:31 PM
Remove/install over axle pipes w/o a lift RainsFather 2005 - 2010 5 February 8th, 2010 02:39 PM
How to remove & install body panels and other parts travis_afx Visual 26 November 8th, 2008 03:26 PM
gauge needles? 02muscle 99-04 4 November 2nd, 2008 09:06 PM
Needles sweeping 01horse 99-04 9 March 11th, 2008 05:54 PM
